Home » Language IDEs » ServerTools (WTP) » adding source and javadocs to packages in webtools plugin for eclipse
adding source and javadocs to packages in webtools plugin for eclipse [message #181542] Thu, 12 October 2006 08:07 Go to next message
I am using the webtools plugin for eclipse and developing web apps using
the "dynamic web project" wizard for a template.
My app uses the spring and hibernate libraries, and I have added these
libs to my WEB-INF/lib folder, and there are available to the app in
eclipse and when I run the app on the server.
However the problem is that these libs do not show up in the libraries
listing, and therefore I cannot add the javadocs for the libraries so
eclipse can automatically use them for context help.
Am I missing something on how to add these libraries to the
webtools/eclipse environment?
Tom H
Re: adding source and javadocs to packages in webtools plugin for eclipse [message #181552 is a reply to message #181542] Thu, 12 October 2006 10:04 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Look for these libraries under the "Web Application Libraries" classpath
container node in the package explorer. You will be able to add src and
javadoc attachments there.
- Konstantin
Re: adding source and javadocs to packages in webtools plugin for eclipse [message #181678 is a reply to message #181552] Tue, 17 October 2006 04:53 Go to previous message
Ah, brilliant, Thanks!
Tom
> - Konstantin
Previous Topic:Web project from CVS source (missing Deployment Descriptor)
Next Topic:problem: XHTML and Code assitant
Current Time: Sun Jul 20 06:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.23921 seconds
