Home » Modeling » M2T (model-to-text transformation) » Parsing OCL constraints in Acceleo
Parsing OCL constraints in Acceleo [message #1815325] Mon, 30 September 2019 11:33 Go to next message
I have a UML model with OCL constraints and I would like to generate code from both, the UML model elements as well as from OCL constraints applied to these. The model is created with MagicDraw and the OCL expressions are contained within UML OpaqueExpressions. I would like to generate a OCLExpression from the body (text) of the OpaqueExpression in order to navigate the OCL syntax in order to map it onto code for test interceptors.
So, in a nutshell: I would like to use from within Acceleo the OclParser to generate an OclExpression from text.
Any assistance will be much appreciated.
Re: Parsing OCL constraints in Acceleo [message #1815434 is a reply to message #1815325] Wed, 02 October 2019 13:20 Go to previous messageGo to next message
You may find you need to do 'nothing'.
Papyrus support UML2Ecore2Java.
Any embedded OCL within the UML should be translated to Ecore EAnnotations so that the OCL2Java functionality embeds in within your Ecore Java.
(You just need to get the Papyrus/UML configuration correct. Sorry I'm not an expert on this.)
Ed Willink
[Updated on: Wed, 02 October 2019 13:20] by Moderator
Re: Parsing OCL constraints in Acceleo [message #1815489 is a reply to message #1815434] Thu, 03 October 2019 08:41 Go to previous message
Thanks, Ed, for the poiinter - will try and give feedback if I managed to get things going ...
Kind regards
Fritz
Previous Topic:Error while creating Acceleo project
Next Topic:[Acceleo] A question on building product with Maven/Tycho
Current Time: Sun Jul 20 18:34:07 EDT 2025
Powered by FUDForum. Page generated in 0.16608 seconds
