eclipselink 2.7.4 and java 13 causes java.lang.IllegalArgumentException [message #1814793] |
Wed, 18 September 2019 07:54  |
when starting an application in Tomcat 9.0.24 with Java 13 (both on Linux 3.10.0-957.27.2.el7.x86_64 and Windows 10) eclipselink throws following errors (see below). The app starts anyway and seems to work correctly (as far as I've seen...)
Is there a workaround or a new version to be expected?
regards
Erich
13:40:01,866 ERROR ECLIPSELINK [(|)] The java.lang.Object class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
java.lang.IllegalArgumentException: Unsupported class file major version 57
at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:184)
at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:166)
at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:152)
at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:273)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.buildClassMetadata(MetadataAsmFactory.java:106)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.getMetadataClass(MetadataAsmFactory.java:177)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAccessibleObject.getMetadataClass(MetadataAccessibleObject.java:73)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataClass.getSuperclass(MetadataClass.java:405)
at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.ClassAccessor.processParentClass(ClassAccessor.java:1695)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.addAccessor(MetadataProject.java:421)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.addEmbeddableAccessor(MetadataProject.java:505)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.initPersistenceUnitClasses(MetadataProcessor.java:374)
at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processEntityMappings(MetadataProcessor.java:563)
at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:625)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:2003)
at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactoryImpl(PersistenceProvider.java:350)
at org.eclipse.persistence.jpa.PersistenceProvider.createContainerEntityManagerFactory(PersistenceProvider.java:316)
at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:365)
at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.buildNativeEntityManagerFactory(AbstractEntityManagerFactoryBean.java:390)
at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:377)
at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.afterPropertiesSet(LocalContainerEntityManagerFactoryBean.java:341)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1837)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1774)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:515)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:320)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:318)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1105)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:549)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:400)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:291)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4683)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5146)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:631)
at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1831)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:526)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:425)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1576)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:936)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:841)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1384)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1374)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:909)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:421)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:932)
at org.apache.catalina.startup.Catalina.start(Catalina.java:633)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:344)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:475)
13:40:01,873 ERROR ECLIPSELINK [(|)] The java.lang.Object class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
java.lang.ArrayIndexOutOfBoundsException: Index 8 out of bounds for length 0
at org.eclipse.persistence.internal.libraries.asm.ClassReader.readUnsignedShort(ClassReader.java:3353)
at org.eclipse.persistence.internal.libraries.asm.ClassReader.<init>(ClassReader.java:188)
at org.eclipse.persistence.internal.libraries.asm.EclipseLinkClassReader.<init>(EclipseLinkClassReader.java:32)
at org.eclipse.persistence.internal.libraries.asm.EclipseLinkClassReader.<init>(EclipseLinkClassReader.java:28)
at org.eclipse.persistence.internal.libraries.asm.EclipseLinkClassReader.<init>(EclipseLinkClassReader.java:24)
at org.eclipse.persistence.internal.jpa.metadata.accessors.objects.MetadataAsmFactory.buildClassMetadata(MetadataAsmFactory.java:123)
13:40:02,073 ERROR ECLIPSELINK [(|)] The java.lang.Enum class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
13:40:02,079 ERROR ECLIPSELINK [(|)] The java.lang.Enum class was compiled with an unsupported JDK. Report this error to the EclipseLink open source project.
FUDForum. Page generated in 0.28455 seconds
