Home » Modeling » M2T (model-to-text transformation) » Code for Model created in Sirius editor
Code for Model created in Sirius editor [message #1815125] Wed, 25 September 2019 13:06 Go to next message
Hi ..
Iam new to Sirius and eclipse and need an urgent guidance.
i have created a DSL and then in new run time configuration..i am able to create system model using the concepts of meta model. Thereafter i graphically represented the system model using Sirius editor and also developed a palette from where i can drag drop the model elements. The problem which iam facing now is :
From where can i find the java code for my system model (which is there in graphical form in Sirius editor). Is it automatically generated or we have to generate it our self.
Thanking in anticipation. REGARDS.
Re: Code for Model created in Sirius editor [message #1815134 is a reply to message #1815125] Wed, 25 September 2019 15:58 Go to previous message
If you want code to be generated automatically you must use a model with a known semantics such as Ecore. Otherwise you are asking the equivalent of where to obtain a MyProprietaryLanguage to French dictionary.
Ed Willink
Previous Topic:Model to text transformation
Next Topic:Error while creating Acceleo project
Current Time: Sun Jul 20 16:47:38 EDT 2025
Powered by FUDForum. Page generated in 0.03109 seconds
