Home » Modeling » M2T (model-to-text transformation) » Model to text transformation(Eclipse Sirius, Acceleo)
Model to text transformation [message #1814799] Wed, 18 September 2019 10:24 Go to next message
Hello all,
I have my meta-model, Model and view specification file. Next steps what i want to generate code from Model to text. Can someone please let me know what will be the next possible steps in order to generate program?
Will be looking forward
Adil
Re: Model to text transformation [message #1814827 is a reply to message #1814799] Thu, 19 September 2019 06:18 Go to previous messageGo to next message
If your modelling technique is standard then you may find a standard conversion, e.g. from an Ecore model to Java.
If you have a proprietary requirement such as targeting Ada compliant with specialist style guidelines expect to write your own M2T.
If you are somewhere in between you may find that an M2M from your custom model to a standard model is less effort.
Ed Willink
Re: Model to text transformation [message #1814859 is a reply to message #1814827] Fri, 20 September 2019 09:21 Go to previous message
Thanks for your quick reply on it. Actually i want to use Acceleo for that as it is my Professor requirement in the university. So any help related to M2T using Acceleo would be very kind of you.
Looking forward,
Have a nice weekend
Adil
Previous Topic:UML diagrams in XML + JET = Java?
Next Topic:Code for Model created in Sirius editor
Current Time: Sun Jul 20 15:48:31 EDT 2025
Powered by FUDForum. Page generated in 0.21754 seconds
