IllegalStateException during maven build of Xtext project [message #1814479] |
Thu, 12 September 2019 02:56  |
Hi all,
During the maven build of an Xtext project I am getting the following error:
[WARNING] Error initializing: org.eclipse.tycho.p2.resolver.P2DependencyResolver@11d045b4
java.lang.RuntimeException: java.lang.IllegalStateException: Service is not registered class='interface org.eclipse.tycho.core.shared.ProxyServiceFacade'
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.checkStarted(DefaultEquinoxEmbedder.java:311)
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.getService(DefaultEquinoxEmbedder.java:285)
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.getService(DefaultEquinoxEmbedder.java:280)
at org.eclipse.tycho.p2.resolver.P2DependencyResolver.initialize(P2DependencyResolver.java:428)
at org.eclipse.sisu.plexus.PlexusLifecycleManager.initialize(PlexusLifecycleManager.java:303)
at org.eclipse.sisu.plexus.PlexusLifecycleManager.activate(PlexusLifecycleManager.java:207)
at org.eclipse.sisu.bean.BeanScheduler$Pending.activate(BeanScheduler.java:156)
at org.eclipse.sisu.bean.BeanScheduler$Activator.onProvision(BeanScheduler.java:185)
at com.google.inject.internal.ProvisionListenerStackCallback$Provision.provision(ProvisionListenerStackCallback.java:126)
at com.google.inject.internal.ProvisionListenerStackCallback.provision(ProvisionListenerStackCallback.java:68)
at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:63)
at com.google.inject.internal.InternalFactoryToInitializableAdapter.get(InternalFactoryToInitializableAdapter.java:45)
at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1016)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1012)
at org.eclipse.sisu.inject.Guice4$1.get(Guice4.java:162)
at org.eclipse.sisu.inject.LazyBeanEntry.getValue(LazyBeanEntry.java:81)
at org.eclipse.sisu.plexus.LazyPlexusBean.getValue(LazyPlexusBean.java:51)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:263)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:255)
at org.eclipse.tycho.core.resolver.DefaultDependencyResolverFactory.lookupDependencyResolver(DefaultDependencyResolverFactory.java:74)
at org.eclipse.tycho.core.resolver.DefaultTychoResolver.setupProject(DefaultTychoResolver.java:95)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:90)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:266)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: java.lang.IllegalStateException: Service is not registered class='interface org.eclipse.tycho.core.shared.ProxyServiceFacade'
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.getService(DefaultEquinoxEmbedder.java:301)
at org.eclipse.tycho.osgi.configuration.OSGiProxyConfigurator.afterFrameworkStarted(OSGiProxyConfigurator.java:41)
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.doStart(DefaultEquinoxEmbedder.java:185)
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.start(DefaultEquinoxEmbedder.java:67)
at org.eclipse.sisu.equinox.embedder.internal.DefaultEquinoxEmbedder.checkStarted(DefaultEquinoxEmbedder.java:309)
... 36 more
[ERROR] Internal error: java.lang.RuntimeException: Could not instantiate required component: com.google.inject.ProvisionException: Unable to provision, see the following errors:
[ERROR]
[ERROR] 1) Error notifying ProvisionListener org.eclipse.sisu.bean.BeanScheduler$Activator of org.eclipse.tycho.core.DependencyResolver annotated with @com.google.inject.name.Named(value=p2).
[ERROR] Reason: java.lang.RuntimeException: java.lang.IllegalStateException: Service is not registered class='interface org.eclipse.tycho.core.shared.ProxyServiceFacade'
[ERROR] while locating org.eclipse.tycho.core.DependencyResolver annotated with @com.google.inject.name.Named(value=p2)
[ERROR]
[ERROR] 1 error
[ERROR] role: org.eclipse.tycho.core.DependencyResolver
[ERROR] roleHint: p2
[ERROR] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: Could not instantiate required component
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:121)
Caused by: java.lang.RuntimeException: Could not instantiate required component
at org.eclipse.tycho.core.resolver.DefaultDependencyResolverFactory.lookupDependencyResolver(DefaultDependencyResolverFactory.java:76)
... 11 more
Caused by: org.codehaus.plexus.component.repository.exception.ComponentLookupException: com.google.inject.ProvisionException: Unable to provision, see the following errors:
1 error
roleHint: p2
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:267)
... 16 more
Caused by: com.google.inject.ProvisionException: Unable to provision, see the following errors:
1 error
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1025)
... 18 more
Caused by: java.lang.RuntimeException: java.lang.IllegalStateException: Service is not registered class='interface org.eclipse.tycho.core.shared.ProxyServiceFacade'
... 22 more
... 36 more
I already found the following solution on stackoverflow: https://stackoverflow.com/questions/48327214/xtext-maven-build-fails-under-jenkins-docker but the proposed solution there unfortunately did not work for me.
Any insight to the problem would be much appreciated!
FUDForum. Page generated in 0.53705 seconds
