Home » Language IDEs » Java Development Tools (JDT) » How to add a custom launcher to a perspective(Adding a launcher to a perspective)
How to add a custom launcher to a perspective [message #1814307] Mon, 09 September 2019 04:56 Go to next message
I am trying to create a custom launcher to run my plugin and I want to add it to my custom perspective. Is there a way to do that? I've tried a couple of times after looking it up online on how to do it but with no success.
Thank you!
Re: How to add a custom launcher to a perspective [message #1814387 is a reply to message #1814307] Tue, 10 September 2019 14:23 Go to previous messageGo to next message
I have a feeling there isn't really a good way to do that. "Local" launchers are stored in the workspace's .metadata, i.e., <workspace>/.metadata/.plugins/org.eclipse.debug.core/.launches/*.launch, so there isn't really a way to contribute that...
Re: How to add a custom launcher to a perspective [message #1814412 is a reply to message #1814387] Wed, 11 September 2019 03:14 Go to previous messageGo to next message
To be more explicit, my plugin creates some custom files written in C. After building the project(make all), I get a file. Let's call it file.extension. Is there a way to pass this file to another application(a simulator for example) with some custom arguments PROGRAMATICALLY?
Thanks!
Re: How to add a custom launcher to a perspective [message #1814424 is a reply to message #1814412] Wed, 11 September 2019 05:20 Go to previous messageGo to next message
If by "pass this file to another application with some custom arguments programmatically" you mean "run a Launch Configuration with custom arguments programmatically" then yes, there are ways to do that.
Basically, once you have created your Launch Configuration type with some arguments [1] then you can create a new Launch Configuration programmatically, set its arguments then launch it. See [2] for an example.
Your code would be something like the following (not tested):
// Create a new Launch Configuration
ILaunchManager manager = DebugPlugin.getDefault().getLaunchManager();
ILaunchConfigurationType type = manager.getLaunchConfigurationType(YOUR_LAUNCH_CONFIGURATION_TYPE_ID);
ILaunchConfigurationWorkingCopy configuration = type.newInstance(null, "Name of the new Launch Configuration");
// Set its attributes (here, we give it the path to the file.extensions you generated)
configuration.setAttribute("generated file", pathToGeneratedFile);
// Launch the configuration
configuration.launch(ILaunchManager.RUN_MODE, new NullProgressMonitor();
In case you want to launch an existing Java application based on JDT's Launch Configuration then I believe that [2] could be a good starting point.
[1] https://www.vogella.com/tutorials/EclipseLauncherFramework/article.html#creating-a-new-launch-configuration-type
[2] https://www.eclipse.org/articles/Article-Java-launch/launching-java.html
Re: How to add a custom launcher to a perspective [message #1814433 is a reply to message #1814424] Wed, 11 September 2019 07:55 Go to previous messageGo to next message
What I mean by "pass this file to another application with some custom arguments programmatically" is the following (just an example, not the actual thing).
1. Run the plugin
2. Workbench opens. I create my type of project
3. Creating the project also created some files inside it.
4. Build the project => I get an executable
5. This executable SHOULD be then passed to an application(to put it more explicit, let's say after building the project I get an image(the executable) and I want to pass that image to, let's say, Photoshop(which is the simulator)) with some arguments.
Hope I was clear enough!
Re: How to add a custom launcher to a perspective [message #1814436 is a reply to message #1814424] Wed, 11 September 2019 08:53 Go to previous messageGo to next message
To be even clearer, after building the project, I get a binary. How can I run that binary with another program by also providing some arguments?
Re: How to add a custom launcher to a perspective [message #1814437 is a reply to message #1814433] Wed, 11 September 2019 08:55 Go to previous messageGo to next message
You can use variables in the launch configuration so you can use Variables... to choose resource_loc and use Configure... to locate the executable in the workspace. Note also that the last tab of the launch configuration lets you specify "Shared File" so you can locate the *.launch in one of your projects in the workspace so that it's always available in every workspace where you've imported your project.
Re: How to add a custom launcher to a perspective [message #1814439 is a reply to message #1814424] Wed, 11 September 2019 09:20 Go to previous messageGo to next message
Sorry for so many messages, I'm just trying to explain the situation as best as possible to maybe give you a bit of help in order to help me.
Basically, what I have to do is create an external tools configuration where I will use Program and need to programmatically specify the location of the program that is going to use the binary, the working directory(which is the project located in the workspace) and the arguments.
Re: How to add a custom launcher to a perspective [message #1814440 is a reply to message #1814439] Wed, 11 September 2019 09:23 Go to previous messageGo to next message
Emmanuel explained how to create a launcher programmatically. Everything you can do in the IDE manually you can do programmatically via the APIs he described and can even launch it programmatically.
Re: How to add a custom launcher to a perspective [message #1814442 is a reply to message #1814440] Wed, 11 September 2019 09:44 Go to previous messageGo to next message
You are very correct. I finally managed, after one week, to create that configuration. But, and I'm hoping you might have an idea, I'm not exactly sure about one thing. I have the method which creates the configuration with all the attributes and value. The problem is, I don't know where to use. Meaning, I have a class which creates my type of project, but I can't put it there because it runs at the same time the project is created and then disappears.
Do you have any ideas?
Re: How to add a custom launcher to a perspective [message #1814453 is a reply to message #1814442] Wed, 11 September 2019 11:21 Go to previous messageGo to next message
Your descriptions are a little vague, but you can save a launch configuration via org.eclipse.debug.core.ILaunchConfigurationWorkingCopy.doSave(int) and can save it in the workspace by calling org.eclipse.debug.core.ILaunchConfigurationWorkingCopy.setContainer(IContainer) first (with IContainer being the IProject or IFolder in which you want it to be saved).
Re: How to add a custom launcher to a perspective [message #1814454 is a reply to message #1814442] Wed, 11 September 2019 11:37 Go to previous message
To be honest, I'm not sure that I trully understand what you are trying to achieve. If I sum up what I understood, your use case is the following:
  • Write some C code
  • Generate a file/executable by building the project
  • Run another binary programmatically, giving it the generated file/executable as an argument
And if have understood your last message correctly, so far you managed to:
  • Generate a file/executable by building your project
  • Programmatically create an External Tool configuration that executes the 'other binary'
and you are currently trying to determine how to run the code that either launches the External Tool or create a Launch Configuration that your users can run as they wish.
Am I right so far?
If that's the case, then you can for instance:
  • add a button in Eclipse IDE's UI that would launch the other binary on press [1]
  • add a dedicated context menu that would allow to launch the other binary by a right-click on your project [1, 2, 3]
  • add a custom Project Builder to your project so that your code is automatically executed after the compilation of your C code [4]
[1] https://www.vogella.com/tutorials/EclipseCommands/article.html
[2] https://www.vogella.com/tutorials/EclipseProjectNatures/article.html
[3] https://www.programcreek.com/2013/02/eclipse-rcp-tutorial-add-a-menu-item-to-the-popup-menu-when-right-click-a-file/
[4] https://www.vogella.com/tutorials/EclipseBuilder/article.html
[Updated on: Wed, 11 September 2019 11:50] by Moderator
Previous Topic:Save/restore project settings from team(git) repository
Next Topic:Debugging - Slow jump to source location
Current Time: Tue May 13 22:46:44 EDT 2025
Powered by FUDForum. Page generated in 0.05062 seconds
