Git status very long since last release 5.4.2 [message #1811312] |
Fri, 30 August 2019 09:24  |
Since switching to version 5.4.2 of egit, at each reopening of eclipse a "git status" is triggered for each repo of my open projects in Eclipse. And this "git status" is very long for some projects with a lot of files and versions.
I'm using eclipse 2019-06, and there was no problem with the previous version of Egit included in eclipse.
Thank you.
Re: Git status very long since last release 5.4.2 [message #1811349 is a reply to message #1811325] |
Sat, 31 August 2019 13:26   |
Thanks for your response.
1: I see the launch of a git status in the "progress" view of Eclipse only when I open Eclipe in the morning: the rest of the day I can not see it.
2 : eclipse 2019-06, and the previous version of egit : 5.4.0.201906121030-r
3 : windows 10, NTFS on SSD
4 : openjdk 1.8 64 bits
5 : Between 1 and 10 minutes. it depends on what other repo runs the git status.
I noticed that in general there is 3 git status in parallel, no more.
If it is on repo very big, the 3 are very slow, and we quickly go to 15 minutes.
This is a corporate post, and the built-in antivirus scans all files, all the time..., and is not deactivatable. So it slows down even more, but before version 5.4.2, I did not have this phenomenon.
6 : 16 repo currently open. I attach to the post a screenshot of the progress view of eclipse at startup.
the 3 biggest have this kind of statistics:
Overall repository size | * Blobs | * Total size | 16.7 GiB
| Biggest objects | * Blobs | * Maximum size [1] | 43.3 MiB
| Biggest checkouts |
| * Number of directories [2] | 5.12 k
| * Maximum path depth [2] | 17
| * Maximum path length [3] | 220 B
| * Total size of files [4] | 1.64 GiB
The others are much smaller.
7: window size : 8 k, window cache limit: 500 m, delta base cache limit : 10 m, stream file threshold : 50 m
Another point: when I go into the perspective "git" of eclipse, a "git status" is triggered for all other repositories for which I have no open project in my workspace.
Thank You.
[Updated on: Sat, 31 August 2019 13:32] by Moderator
FUDForum. Page generated in 0.43507 seconds
