Error Restarting AUT from Test Runner [message #1706440] |
Wed, 26 August 2015 16:18  |
I've attached the error message: "Missing System Property - Unable to relaunch the platform because the eclipse.vm property has not been set."
My system's JAVA_HOME is 1.7 due to many applications that require it, but our project is 1.8.
I've applied the argument:
-autVM "C:\dev\Java80\sdk\jre"
which results in the application working correctly. However, when I attempt to restart AUT in the middle of a test, I get the error.
In addition, to try to fix it, I tried:
-autVMArgs -vm [path\to\javaw.exe]
and that did not remedy the problem (I may have not been inputting it correctly). The application works fine when using normally, and fine when running it from RCPTT in the normal GUI environment. I tried to google the issue, but it hasn't helped very much.
Attachment: Capture.JPG
(Size: 18.53KB, Downloaded 266 times)
[Updated on: Wed, 26 August 2015 16:20] by Moderator
Re: Error Restarting AUT from Test Runner [message #1811313 is a reply to message #1706440] |
Fri, 30 August 2019 09:40  |
Strange thing...
I have an AUT buildt on Eclipse 4.4 / 4.6 which is working fine in RCPTT IDE 2.4.2, but is not starting in RCPTT Test Runner. Any reason why?
!SESSION 2019-08-30 14:10:49.152 -----------------------------------------------
eclipse.buildId=unknown
java.fullversion=8.0.5.25 - pwa6480sr5fp25-20181030_01(SR5 FP25)
JRE 1.8.0 Windows 7 amd64-64-Bit Compressed References 20181029_400846 (JIT enabled, AOT enabled)
OpenJ9 - c5c78da
OMR - 3d5ac33
IBM - 8c1bdc2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product com.ibm.team.concert.product -eclipse.keyring X:\\runner-workspace\.metadata\.plugins\org.eclipse.pde.core\AUT_0/secure_storage
Command-line arguments: -product com.ibm.team.concert.product -data X://aut-workspace0 -dev file:X://runner-workspace/.metadata/.plugins/org.eclipse.pde.core/AUT_0/dev.properties -os win32 -arch x86_64 -consoleLog -eclipse.keyring X:\\runner-workspace\.metadata\.plugins\org.eclipse.pde.core\AUT_0/secure_storage
!ENTRY org.eclipse.rcptt.tesla.gmf 4 0 2019-08-30 14:10:54.876
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.gmf [2183]
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.core
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.rcptt.tesla.gmf.aspects 4 0 2019-08-30 14:10:54.878
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.gmf.aspects [2184]
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui
!ENTRY org.eclipse.rcptt.tesla.nebula.ecl.impl 4 0 2019-08-30 14:10:54.881
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.nebula.ecl.impl [2198]
Unresolved requirement: Require-Bundle: org.eclipse.rcptt.tesla.nebula.impl; bundle-version="[2.4.2,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.rcptt.tesla.nebula.impl; bundle-version="2.4.2.201903220647"; singleton:="true"
org.eclipse.rcptt.tesla.nebula.impl [2199]
Unresolved requirement: Require-Bundle: org.eclipse.nebula.widgets.grid
!ENTRY org.eclipse.rcptt.tesla.nebula.impl 4 0 2019-08-30 14:10:54.888
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.nebula.impl [2199]
!ENTRY org.eclipse.rcptt.tesla.recording.aspects.gmf 4 0 2019-08-30 14:10:54.894
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.aspects.gmf [2204]
!ENTRY org.eclipse.rcptt.tesla.recording.gmf 4 0 2019-08-30 14:10:54.898
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.gmf [2215]
Unresolved requirement: Require-Bundle: org.eclipse.rcptt.tesla.recording.aspects.gmf; bundle-version="[2.4.2,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.rcptt.tesla.recording.aspects.gmf; bundle-version="2.4.2.201903220647"; singleton:="true"
!ENTRY org.eclipse.rcptt.tesla.recording.nebula 4 0 2019-08-30 14:10:54.903
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.nebula [2217]
!ENTRY org.eclipse.osgi 4 0 2019-08-30 14:10:58.109
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.jobs (1405).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:419)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:853)
at org.eclipse.core.internal.runtime.InternalPlatform.start(InternalPlatform.java:719)
at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformActivator.java:32)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(AccessController.java:703)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:757)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:270)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:331)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at java.lang.Thread.run(Thread.java:812)
Caused by: org.aspectj.apache.bcel.classfile.ClassFormatException: org.eclipse.core.internal.jobs.JobActivator is not a Java .class file
at org.aspectj.apache.bcel.classfile.ClassParser.readID(ClassParser.java:215)
at org.aspectj.apache.bcel.classfile.ClassParser.parse(ClassParser.java:124)
at org.aspectj.weaver.bcel.Utility.makeJavaClass(Utility.java:467)
at org.aspectj.weaver.bcel.BcelWorld.addSourceObjectType(BcelWorld.java:515)
at org.aspectj.weaver.tools.WeavingAdaptor.ensureDelegateInitialized(WeavingAdaptor.java:513)
at org.aspectj.weaver.tools.WeavingAdaptor$WeavingClassFileProvider.<init>(WeavingAdaptor.java:843)
at org.aspectj.weaver.tools.WeavingAdaptor.getWovenBytes(WeavingAdaptor.java:526)
at org.aspectj.weaver.tools.WeavingAdaptor.weaveClass(WeavingAdaptor.java:363)
at org.eclipse.equinox.weaving.aspectj.loadtime.OSGiWeavingAdaptor.weaveClass(Unknown Source)
at org.eclipse.equinox.weaving.aspectj.AspectJWeavingService.preProcess(Unknown Source)
at org.eclipse.equinox.weaving.adaptors.WeavingAdaptor.weaveClass(Unknown Source)
at org.eclipse.equinox.weaving.hooks.WeavingHook.processClass(Unknown Source)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:616)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:586)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525)
... 59 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-08-30 14:10:58.114
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.runtime (1422).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle org.eclipse.core.runtime.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
Caused by: java.lang.NoClassDefFoundError: org.eclipse.core.runtime.jobs.Job
... 41 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.jobs (1405).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
... 47 more
Caused by: org.osgi.framework.BundleException: Error starting module.
... 56 more
... 59 more
Root exception:
... 47 more
... 56 more
... 59 more
!ENTRY org.eclipse.osgi 4 0 2019-08-30 14:10:58.117
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.trace (2355).
!STACK 0
org.osgi.framework.BundleException: Error loading bundle activator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:716)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.runtime (1422).
... 26 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle org.eclipse.core.runtime.
... 34 more
... 41 more
... 47 more
... 56 more
... 59 more
Root exception:
... 34 more
... 41 more
... 47 more
... 56 more
... 59 more
!ENTRY org.eclipse.equinox.ds 4 0 2019-08-30 14:10:58.121
!MESSAGE Exception occurred while creating new instance of component Component[
name = org.eclipse.ui.trace.TracingInitializer
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = org.eclipse.ui.trace.internal.utils.TracingInitializer
state = Disposed
properties =
serviceFactory = false
serviceInterface = null
references = {
Reference[name = DebugOptionsListener, interface = org.eclipse.osgi.service.debug.DebugOptionsListener, policy = static, cardinality = 1..n, target = null, bind = null, unbind = null]
located in bundle = org.eclipse.ui.trace_1.0.400.v20160509-1055 [2355]
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.trace (2355).
at org.ec
FUDForum. Page generated in 0.26444 seconds
