Home » Eclipse Projects » Kura » Auto create driver instance, assets and channels(Configure driver instance, assets and channels from code)
Auto create driver instance, assets and channels [message #1810476] Mon, 12 August 2019 10:58 Go to next message
Hi everyone,
I've just started learning Kura and OSGI. I developed a new driver that extends Driver and ConfigurableComponent. Now, I'm trying to automatically create a driver instance, assets and channels without using the Web UI.
I looked into "Assets REST APIs" but it only provides Get methods for Assets and Channels. I tried to see how it is done by the Web UI but I got lost in code. In the Eclipse Kura Documentation, it always refers to the Web UI.
I'm trying to find something like "setAssets(List<Asset>)" and "setChannels(List<Channel>)".
Can you please point me to right direction?
Thank you for any help.
Re: Auto create driver instance, assets and channels [message #1810490 is a reply to message #1810476] Mon, 12 August 2019 12:50 Go to previous messageGo to next message
we usually do that using the ConfigurationService. Here the reference to the method that can be used: https://github.com/eclipse/kura/blob/develop/kura/org.eclipse.kura.api/src/main/java/org/eclipse/kura/configuration/ConfigurationService.java#L139
I believe you can find many references to this method here and there in the code.
Matteo
Re: Auto create driver instance, assets and channels [message #1810898 is a reply to message #1810490] Wed, 21 August 2019 08:59 Go to previous message
Hi Matteo,
Thank you for your response. It was really helpful :-)
Best regards.
Previous Topic:Db operation failed
Next Topic:Problem using KURA Client to connect to AWS IoT
Current Time: Sun Jul 20 13:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.04625 seconds
