Home » Language IDEs » Java Development Tools (JDT) » Unable to Install JBoss Tools Plugin on Photon(Unable to read repository for JBoss Tools via Eclipse Marketplace)
Unable to Install JBoss Tools Plugin on Photon [message #1810234] Mon, 05 August 2019 10:47 Go to next message
I'm receiving an error when trying to install JBoss Tools 4.6.0.Final on my Eclipse Java EE IDE for Web Developers Version Phton Release (4.8.0). This is a fresh install of Eclipse while using an existing workspace. I've tried with and without a proxy, both resulting in the following error:
Unable to read repository at http://download.jboss.org/jbosstools/photon/stable/updates/content.xml.
sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I'm not sure if this is the source of the issue.. but one thing I noticed is when I tried navigating to the repository on my browser, I don't see a file with the name content.xml.. I do, however, see a file named compositeContent.xml. Is it supposed to point to content.xml or compositeContent.xml? I couldn't find a way to update where it points to in the Eclipse Preferences.
I've tried the latest version of Eclipse Java EE (2019/06) and Eclipse version Oxygen, trying to install the appropriate JBoss Tools plugin in the marketplace.. but still results in the same error. I've tried downloading the zip of the JBoss Tools and using "Install New Software", but this also did not work.
This is my first time posting on the forum.. so please let me know if I need to include more information.
Please help, I'm running out of ideas.
[Updated on: Wed, 14 August 2019 13:39] by Moderator
Re: Unable to Install JBoss Tools Plugin on Photon [message #1810583 is a reply to message #1810234] Tue, 13 August 2019 12:51 Go to previous messageGo to next message
Then no error follows, looks like you forgot to include the most important part of your post :)
OTOH, this is not the forum where JBoss tools are discussed, they certainly have their own forum, don't they?
Re: Unable to Install JBoss Tools Plugin on Photon [message #1810632 is a reply to message #1810234] Wed, 14 August 2019 13:38 Go to previous messageGo to next message
Matthew Ro wrote on Mon, 05 August 2019 14:47
Re: Unable to Install JBoss Tools Plugin on Photon [message #1810634 is a reply to message #1810632] Wed, 14 August 2019 13:59 Go to previous message
In a comment at the marketplace entry of JBoss Tools I see a similar problem. That's where you should watch for an answer.
Previous Topic:JAVA IDE
Next Topic:Task Tags not showing in Task Pane
Current Time: Sat Jul 19 17:22:55 EDT 2025
Powered by FUDForum. Page generated in 0.05120 seconds
