Home » Language IDEs » Java Development Tools (JDT) » Can't open file from Linux shell on active session
Can't open file from Linux shell on active session [message #1810528] Tue, 13 August 2019 04:35 Go to next message
I been trying and failing for long time to open a file from linux shell but NOT AS NEW Eclipse session. I have Eclipse instance running and I want it to be opened there.
I tried:
eclipse <file_path>
and:
eclipse --launcher.openFile <file_path>
in any case it tries to open new session and then says that the workspace is currently in use by another Eclipse application.
My version is: Eclipse version: Neon.3 Release (4.6.3)
Anyone knows how to make it work??.....
German
[Updated on: Tue, 13 August 2019 09:15] by Moderator
Re: Can't open file from Linux shell on active session [message #1810559 is a reply to message #1810528] Tue, 13 August 2019 09:40 Go to previous messageGo to next message
It works just fine for me using Eclipse 4.12
With 4.6.3 your missing out *many* bugfixes made since then ...
Re: Can't open file from Linux shell on active session [message #1810563 is a reply to message #1810559] Tue, 13 August 2019 09:44 Go to previous messageGo to next message
I have some mandatory plugins that are not supported in Eclipse 4.7 and higher.
Re: Can't open file from Linux shell on active session [message #1810565 is a reply to message #1810563] Tue, 13 August 2019 10:24 Go to previous message
You may still want to try if it works using a recent version of Eclipse, to figure out if its fixed indeed or if something else causes the problem on your system.
Previous Topic:Maven Plugin and Maven Project in Eclipse
Next Topic:How to install Java Development Kit
Current Time: Sun Jul 20 04:15:51 EDT 2025
Powered by FUDForum. Page generated in 0.03751 seconds
