Home » Eclipse Projects » Kura » Db operation failed(java.sql.SQLException: Database instance not initialized)
Db operation failed [message #1810526] Tue, 13 August 2019 03:39 Go to next message
I am receiving the following error
2019-08-13T13:02:29,326 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger - Received WireEnvelope from org.eclipse.kura.wire.WireAsset-1565677757718-147
2019-08-13T13:02:29,326 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger - Record List content:
2019-08-13T13:02:29,327 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger -   Record content:
2019-08-13T13:02:29,327 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger -     Channel-1_timestamp : 1565681549307
2019-08-13T13:02:29,327 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger -     assetName : Modbusrunner
2019-08-13T13:02:29,327 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger -     Channel-1 : 0
2019-08-13T13:02:29,328 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.i.w.l.Logger -     Channel-1_error :
2019-08-13T13:02:34,312 [DefaultQuartzScheduler_Worker-1] INFO  o.e.k.c.d.DataServiceImpl - Storing message on topic: #account-name/#client-id/W1/A1, priority: 7
2019-08-13T13:02:34,313 [DefaultQuartzScheduler_Worker-1] WARN  o.e.k.c.d.H2DbServiceImpl - Db operation failed
	at org.eclipse.kura.core.db.H2DbServiceImpl.getConnectionInternal(H2DbServiceImpl.java:315)
	at org.eclipse.kura.core.db.H2DbServiceImpl.withConnection(H2DbServiceImpl.java:161)
	at org.eclipse.kura.core.data.store.DbDataStore.withConnection(DbDataStore.java:600)
	at org.eclipse.kura.core.data.store.DbDataStore.getMessageCount(DbDataStore.java:227)
	at org.eclipse.kura.core.data.store.DbDataStore.store(DbDataStore.java:258)
	at org.eclipse.kura.core.data.DataServiceImpl.publish(DataServiceImpl.java:529)
	at org.eclipse.kura.core.cloud.CloudServiceImpl.publish(CloudServiceImpl.java:994)
	at org.eclipse.kura.core.cloud.publisher.CloudPublisherImpl.publish(CloudPublisherImpl.java:171)
	at org.eclipse.kura.internal.wire.publisher.CloudPublisher.publish(CloudPublisher.java:256)
	at org.eclipse.kura.internal.wire.publisher.CloudPublisher.onWireReceive(CloudPublisher.java:173)
	at org.eclipse.kura.internal.wire.helper.WireSupportImpl.updated(WireSupportImpl.java:164)
	at org.eclipse.kura.internal.wire.publisher.CloudPublisher.updated(CloudPublisher.java:186)
	at org.eclipse.equinox.internal.wireadmin.WireImpl.update(WireImpl.java:193)
	at org.eclipse.kura.internal.wire.helper.WireSupportImpl$EmitterPortImpl.emit(WireSupportImpl.java:196)
	at org.eclipse.kura.internal.wire.helper.WireSupportImpl.emit(WireSupportImpl.java:126)
	at org.eclipse.kura.internal.wire.asset.WireAsset.emitChannelRecords(WireAsset.java:309)
	at org.eclipse.kura.internal.wire.asset.WireAsset.emitAllReadChannels(WireAsset.java:234)
	at org.eclipse.kura.internal.wire.asset.WireAsset.onWireReceive(WireAsset.java:212)
	at org.eclipse.kura.internal.wire.asset.WireAsset.updated(WireAsset.java:395)
	at org.eclipse.kura.internal.wire.timer.EmitJob.execute(EmitJob.java:63)
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)
2019-08-13T13:02:34,316 [DefaultQuartzScheduler_Worker-1] ERROR o.e.k.i.w.p.CloudPublisher - Error in publishing wire records using cloud publisher..
org.eclipse.kura.KuraStoreException: "Error performing operation on store. Cannot get message count"
	at org.eclipse.kura.core.data.store.DbDataStore.withConnection(DbDataStore.java:602)
Caused by: java.sql.SQLException: Database instance not initialized
	... 23 more
This occurred while trying to publish data using mqtt, What is the solution for this.
Re: Db operation failed [message #1810648 is a reply to message #1810526] Thu, 15 August 2019 02:44 Go to previous message
I believe you need to provide more context on what is your setup and what you are trying to achieve.
From the log it seems that the database you are trying to use is not initialised. Are you using a different instance from the default one?
Are you using wires? If so, what is the graph and the component's configuration.
Maybe you can review all the components' configuration and see if you changed something from the default one that caused the issue.
Matteo
Previous Topic:Wire Graph thread blocked
Next Topic:Auto create driver instance, assets and channels
Current Time: Sun Jul 20 11:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.05136 seconds
