Home » Eclipse Projects » Eclipse 4 » integrating custom help on click of next and previous in custom spring boot wizard( integrating custom help on click of next and previous in custom spring boot wizard)
integrating custom help on click of next and previous in custom spring boot wizard [message #1810376] Thu, 08 August 2019 23:51 Go to next message
I have a custom wizard project which converts monolithic applications to microservice and extends spring boot wizard.My page extends WizardPage and I have overridden performHelp method to open the static help page in browser on click of "?".
Now, I want to integrate the dynamic help(as it occurs in all projects of eclipse) on click of next and previous in new custom wizard i.e. if I click "?" on first page,relevant content should be displayed,on clicking next and on click of "?" on that page specific content should be displayed.
Also,extension points used in my custom project are:
org.eclipse.ui.commands
org.eclipse.ui.handlers
org.eclipse.ui.menus
Any help would be appreciated.
Bhavi
Re: integrating custom help on click of next and previous in custom spring boot wizard [message #1810380 is a reply to message #1810376] Fri, 09 August 2019 02:47 Go to previous messageGo to next message
Dynamic help link integration can be performed through extension point.
In your wizard "?" action you have to create one scope under which your help content can be populated. As soon as you click on question mark it will populate your specific content in help page.
Re: integrating custom help on click of next and previous in custom spring boot wizard [message #1810443 is a reply to message #1810380] Mon, 12 August 2019 02:52 Go to previous message
Can you please let me know the following things
a) which extension point is required in this case
b) sample code for creating scope
c) how to populate custom content on click of "next" and "previous" in the wizard page
Previous Topic:Problem using new transient ui element feature
Next Topic:e4 Switch perspectives
Current Time: Sun Jul 20 08:21:06 EDT 2025
Powered by FUDForum. Page generated in 0.03746 seconds
