Re: Transformation of profile UML from OMG (*.xmi) in a metamodel for use in Sirius. [message #1810355 is a reply to message #1810342] |
Thu, 08 August 2019 13:51  |
Thanks for the answer!
I try to use Sirius for creation of an operating breadboard model of tool MDA integrating a chain "the enterprise system the software" on the basis of almost unlimited mechanisms of expansion UML.
I do all expansions as profiles UML and I generate from them metamodels.
For creation of profiles I use modified plug-ins UML Designer. To execute assemblage UML Designer from Git to me it was not possible. The official version does not contain the necessary elements from profile Standatd.
As a prototype of some technical decisions at creation VPS I use source code UML Designer. I hope, nobody will take offence. I am not engaged in commerce, copyrights I do not break.
Metamodel UML exists: http://www.eclipse.org/uml2/5.0.0/UML (it uses UML Designer) and http://www.eclipse.org/uml2/5.0.0/UML/Profile/Standatd
Metamodel SysML in open access has not found, but there is a profile file SysML.xmi on site OMG: http://www.omg.org/spec/SysML/20161101/SysML. For testing I have made a small fragment of a profile under specification SysML and have generated a metamodel.
The fragment of a metamodel of the enterprise has made itself on prototypes UPIA (IBM), UAF (OMG). Profile UAF too is in the form of a file uafp.xmi.
Ecore model of profiles from OMG in a format xmi does not perceive. Or, I not so do something.
Future to "print" profiles under specifications does not seduce.
Once again thanks.
Leonid Novikov
FUDForum. Page generated in 0.12165 seconds
