Home » Eclipse Projects » Eclipse 4 » Adding Help to an E4 RPC application(How do I add help to an E4 RPC application)
Adding Help to an E4 RPC application [message #1807534] Sun, 02 June 2019 02:48 Go to next message
I am in the final stages of converting an Eclipse 3.x application to E4 and now need to integrate the help.
Previously I had Help through the"org.eclipse.help.toc" plugin point using html files and a toc.xml.
Is there any supported or standard way to build a help menu in E4?
Re: Adding Help to an E4 RPC application [message #1810120 is a reply to message #1807534] Wed, 31 July 2019 14:15 Go to previous messageGo to next message
Hi trevor, i'm in the same page. If you find something , please share it in this thread.
Thanks.
Re: Adding Help to an E4 RPC application [message #1810150 is a reply to message #1810120] Thu, 01 August 2019 09:39 Go to previous messageGo to next message
This would be your starting point:
https://www.eclipse.org/forums/index.php/t/1067847/
Re: Adding Help to an E4 RPC application [message #1810159 is a reply to message #1810120] Thu, 01 August 2019 19:01 Go to previous message
I completely gave up on trying to migrate to E4. The E4 project overall seems mostly abandoned IMHO and there are so many things available in E3 that are completely missing from E4 that it was just too difficult a task.
Previous Topic:Problem Detach Oxygen
Next Topic:Sending events to single window only
Current Time: Sat Jul 19 23:16:39 EDT 2025
Powered by FUDForum. Page generated in 0.05096 seconds
