Home » Eclipse Projects » Eclipse Scout » Move the Menu of Desktop into Outline
Move the Menu of Desktop into Outline [message #1809827] Wed, 24 July 2019 02:46 Go to next message
Hey guys,
i may have a strange question. Maybe i tried it at the wrong points, but i just cant find a working way.
The basic need why i want(need) to do it is, we have a custom DenseMode Setting in which the menu in the upper right corner will disappear and the user wont be able to logout if he doesnt exit DenseMode before.
So what i want to achieve is to put the UserMenu from the place it is to the outlilne itself. There it may be shown as an icon or text (link?) that doesnt matter at all.
Is there any chance to achieve this?
Excuse my poor drawing, i hope you still get what i want to do.
Thx in advance for your ideas.
index.php/fa/35995/0/
  • Attachment: outline.png
    (Size: 60.90KB, Downloaded 422 times)
Re: Move the Menu of Desktop into Outline [message #1809894 is a reply to message #1809827] Thu, 25 July 2019 07:12 Go to previous messageGo to next message
you have several options:
index.php/fa/36006/0/
The simplest one would be to use a header menu. Just put this in your outline:
  @Order(2000)
  public class ProfileHeaderMenu extends AbstractFormMenu {
    protected String getConfiguredIconId() {
      return Icons.PersonSolid;
    protected Set<? extends IMenuType> getConfiguredMenuTypes() {
      return CollectionUtility.hashSet(TreeMenuType.Header);
    protected Class getConfiguredForm() {
      return UserForm.class;
You could also create a view button. But unfortunately the view button will change its background-color as soon as it is clicked even though it is not explicitly marked as toggle button. This is probably not what you want. To circumvent it you could override the rule using CSS.
ViewButton in Desktop.java:
  @Order(3)
  public class ProfileViewButton extends AbstractViewButton {
    protected DisplayStyle getConfiguredDisplayStyle() {
      return DisplayStyle.TAB;
    protected void execAction() {
      new UserForm().start();
Another option would be a regular tree node / page. Either open your user form as dialog or use a detail form to embed it.
TreeNode in Outline.java:
    pageList.add(new AbstractPageWithNodes() {
      protected String getConfiguredTitle() {
        return "Profile";
      protected boolean getConfiguredLeaf() {
        return true;
      protected void execPageActivated() {
If you wanted to place it on the bottom left corner, then you would need to write some JS code (basically extend DesktopNavigation.js or Outline.js and put the widget there).
Cheers
Claudio
Re: Move the Menu of Desktop into Outline [message #1810026 is a reply to message #1809894] Mon, 29 July 2019 09:46 Go to previous messageGo to next message
Cheers Claudio,
it worked like a charm thank you for the help.
Theres just one little thing which i dont understand, if i set the header visible to false and set it back to true (each with an app link in that menu) the Icon in the upper right corner disappears and wont show up again.
Ill investigate a little more into that, maybe you know why :)
Re: Move the Menu of Desktop into Outline [message #1810068 is a reply to message #1810026] Tue, 30 July 2019 04:58 Go to previous messageGo to next message
Hi Maddes,
this is a known bug which was fixed some months ago. Which version do you use? The commit containing the fix is this one: https://github.com/eclipse-scout/scout.rt/commit/1abb84d6e9790a1c4c6256d2615c019d7e157059 . You can test it with the widgets app, there is a check box called "header visible": https://scout.bsi-software.com/widgets/?dl=widget-desktop
[Updated on: Tue, 17 August 2021 09:52] by Moderator
Re: Move the Menu of Desktop into Outline [message #1810070 is a reply to message #1810068] Tue, 30 July 2019 05:21 Go to previous message
Ah ok i see that. I didnt update my Version yet.
Im running 9.0.0.009_Simrel_2019_03 at the moment.
Thank you for your help :)
Previous Topic:Null Pointer Exception when working with editable tables
Next Topic:Using PDF.js under JSP (Tomcat)
Current Time: Sun Jul 20 12:02:21 EDT 2025
Powered by FUDForum. Page generated in 0.04462 seconds
