Home » Modeling » Papyrus » Creating a Diagram from .uml (Component Diagram)(I want to create a papyrus diagram from .uml file)
Creating a Diagram from .uml (Component Diagram) [message #1809712] Sun, 21 July 2019 19:23 Go to next message
I have made a QVTo transformation from a custom model to an uml mode (Component)l. Now, I need to create the diagram from the resulting uml model and see it in Papyrus. How do I do? I need this process be automatized, even open the diagram in the editor when the uml model is created.
[Updated on: Sun, 21 July 2019 19:43] by Moderator
Re: Creating a Diagram from .uml (Component Diagram) [message #1810017 is a reply to message #1809712] Mon, 29 July 2019 06:53 Go to previous messageGo to next message
Hi Daniel,
You have some possibilities to create your diagram:
1. You can create it within your QVTo Transformation as we already did in Papyrus Interoperability for example
2. Or, you can create it programmatically in your code, as we already did in Papyrus example plug-ins for example (this method is a way simple than the previous one)
If you want to have one example, tell me how you want it and i'll share you this one.
HTH,
Nicolas.
Re: Creating a Diagram from .uml (Component Diagram) [message #1810158 is a reply to message #1810017] Thu, 01 August 2019 14:30 Go to previous messageGo to next message
Hello Nicolas,
Thank you for your reply. I am very interesting on the second option. In order to overcome my problem, I created programmatically a transformation from my .uml to PlantUML language and then this tool represents automatically the component diagram. Nevertheless, PlantUml needs DOT which is a third party application. So, if you provide me an example I will be grateful to you.
Currently I am developing in eclipse 2018-12. Is there a problem with it?
You can send me the example as an attachment in this thread.
Daniel
Re: Creating a Diagram from .uml (Component Diagram) [message #1810222 is a reply to message #1810158] Mon, 05 August 2019 05:55 Go to previous message
Sorry for the delay of my reply.
To create component diagram programmatically, you can find the command
CreateComponentDiagramCommand
in the
org.eclipse.papyrus.uml.diagram.component
plug-in.
Moreover, can can find an example in the tests plug-in of component diagram : https://git.eclipse.org/c/papyrus/org.eclipse.papyrus.git/tree/tests/junit/plugins/uml/diagram/org.eclipse.papyrus.uml.diagram.component.tests
HTH,
Nicolas.
Previous Topic:Relationship Generic Matrix
Next Topic:State machine diagram using papyrus
Current Time: Sun Jul 20 14:10:11 EDT 2025
Powered by FUDForum. Page generated in 0.24919 seconds
