Home » Archived » Jubula » Cannot start AutAgent on MAC
Cannot start AutAgent on MAC [message #1809174] Wed, 10 July 2019 10:28 Go to next message
I am evaluating Jubula to use for testing an eclipse plugin. The plugin runs as part of the eclipse IDE so my AUT is effectively the eclipse IDE with the plugin installed.
I am evaluating on MacOS 10.14.5, java version "1.8.0_144"
Have managed to set an eclipse IDE as my AUT, connected it to Jubula using the embedded AutAgent and done the object mapping.
Now when I run my test I can't get anything to work and I see in the status bar:
Connected to AUT Agent localhost 60001 : No connection to AUT
Reading the doc i see that the embedded AUT Agent
"cannot be used for working with the Test Executor"
As a result I try start the AutAgent locally both by double clicking the app but that crashes:
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000034
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [4247]
and running from the command line:
./autrun -rcp -p 60000 -a localhost -i "testAut" -e ./Autagent.app/Contents/MacOS/autagent
which fails:
"The connection to the AUT Agent could not be made.
Please check that you have started the AUT Agent, and
that your connection settings (hostname, port number) are correct."
Please help.
Re: Cannot start AutAgent on MAC [message #1809434 is a reply to message #1809174] Tue, 16 July 2019 03:18 Go to previous message
Martin Mulholland wrote on Wed, 10 July 2019 16:28
Can you point me to the location in the Documentation? We might have missed this place. It is possible to use the embedded Autagent within the testexec.
The testexec does not need any external AUTAgent anymore if you want to run the test locally on the computer. See the testexec documentation for more information[1]. The testexec can start an embedded Agent as well as the Application.
That the external agent is not working nevertheless is not good.
best regards
Marvin Mueller
[1] https://help.eclipse.org/2019-06/topic/org.eclipse.jubula.client.ua.help/content/html/userManual/tasks/ch03s25s03.html
[Updated on: Tue, 16 July 2019 03:19] by Moderator
Previous Topic:Formatting values read into a variable
Next Topic:Object Mapping Menu Bar
Current Time: Sun Jul 20 16:06:48 EDT 2025
Powered by FUDForum. Page generated in 0.03983 seconds
