Home » Eclipse Projects » Sirius » Why does Sirius display an image with an exception?(Sirius)
Why does Sirius display an image with an exception? [message #1808586] Thu, 27 June 2019 06:42 Go to next message
I use some source code to run UMLDesigner, why sirius can add elements to the diagram, but the last open diagram can not be displayed when rerunning, some elements will be lost
Re: Why does Sirius display an image with an exception? [message #1808593 is a reply to message #1808586] Thu, 27 June 2019 08:51 Go to previous messageGo to next message
I don't know what happens in your source code, but the editor indicates that something is unexpectedly null. Can you open the "Error log" view and copy the stack trace with the Null Pointer Exception?
Steve
Re: Why does Sirius display an image with an exception? [message #1808653 is a reply to message #1808593] Fri, 28 June 2019 04:32 Go to previous messageGo to next message
From your screenshot, it seems that your installation might be incomplete: if you compare with the screenshots on http://www.umldesigner.org/tutorials/tuto-getting-started.html for exemple, you will notice UML2 icons displayed in the model explorer when the model tree is expanded.
Furthermore I notice that your uc diagram is displayed in gray, this generally means that the "targeted" uml element (the element on which you created the diagram) no more exist. It also seems that you are in the Resource perspective and the Modeling Perspctive is not open nor active. You might need to check your installation.
How did you create the model, the diagram ?
Did you modify the uml model outside of UML Designer ?
Which version of UML Designer do you use ? or how did you install it in your environment ?
Maxime
Re: Why does Sirius display an image with an exception? [message #1809059 is a reply to message #1808653] Mon, 08 July 2019 03:55 Go to previous messageGo to next message
Thank you very much for your reply, I understand what you mean, the software is running without problems, I am compiling some of the source code to run.
Re: Why does Sirius display an image with an exception? [message #1809060 is a reply to message #1808593] Mon, 08 July 2019 04:06 Go to previous message
There is no problem running now, but I still don't understand where the error is. I guess the reference to the uml element in Viewpoint is abnormal. I used to refer to the uml's jar package of eclipse. Now I am using the eclipse modeling development environment. The uml plugin already exists in the development environment.
This is the error message:
!ENTRY org.eclipse.ui 4 4 2019-06-24 18:15:55.067
!MESSAGE Unable to initialize part
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.sirius.ui.business.internal.dialect.editor.DialectEditorCloserFilter.<init>(DialectEditorCloserFilter.java:47)
at org.eclipse.sirius.ui.business.internal.dialect.editor.DialectEditorCloser.<init>(DialectEditorCloser.java:47)
at org.eclipse.sirius.ui.business.internal.session.EditingSession.attachEditor(EditingSession.java:161)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.init(DDiagramEditorImpl.java:514)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:333)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:990)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:955)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:666)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:772)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:743)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:721)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1289)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:684)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:680)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:551)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:535)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:137)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:79)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:61)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:704)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1081)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Previous Topic:Problems while editing double attributes with Text-Widget
Next Topic:How to activate the filter programatically in eclipse sirius
Current Time: Sun Jul 20 12:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.03900 seconds
