Cannot install Eclipse IDE for C/C++ Developers [message #1808885] |
Wed, 03 July 2019 20:02  |
Hi folks,
I'm stuck. I'm a complete newbie to coding besides some java I picked up in high school over a decade ago. I just started a Udemy course and I'm trying to get everything I need installed.
I am trying to install Eclipse IDE for C/C++ Developers. I have already installed on my computer Java 8 with update 211, and Jave SE Development Kit 12.0.2 (64-bit). That's it though. I'm really disoriented and would appreciate things explained to me in simple terms.
On the install screen it ask for a Jave 1.8+ VM destination folder. Mine currently says C:\program files\java\jdk-12/0/1)Current). This seems to be automatic. The install folder is currently listed as D:\cpp-2019-064
When I install the green bar gets about 2/3 of the way filled, and then I get a long error log. Here is the section of the beginning of the errors:
[2019-07-03 16:57:25] Downloading epp.package.cpp.executable.win32.win32.x86_64
[2019-07-03 16:57:25] Collected 1 artifacts for http://download.eclipse.org/technology/epp/packages/2019-06 in 0.243s
[2019-07-03 16:57:25] An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
[2019-07-03 16:57:25] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while collecting items to be installed
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:548)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:751)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3824)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3752)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3733)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3626)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.installPerform(SimpleVariablePage.java:1298)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.access$32(SimpleVariablePage.java:1166)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage$20.run(SimpleVariablePage.java:1111)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=D__cpp-2019-064_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Failed to transfer artifact canonical: binary,org.eclipse.platform.ide.executable.win32.win32.x86_64,4.12.0.I20190605-1800.
ERROR: org.eclipse.equinox.p2.artifact.repository code=13 Retry another mirror
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 Problems downloading artifact: binary,org.eclipse.platform.ide.executable.win32.win32.x86_64,4.12.0.I20190605-1800.
ERROR: org.eclipse.equinox.p2.artifact.repository code=1203 SHA-256 hash is not as expected. Expected: 6086a8ce00fc071dab7a270dcac36f3c80700ca8caf7f8969825a8de0e840ca7 and found 4a2c3a27071f85ff7297569efc9979fa1e7edda4e372fcbbd0b33b88eb0a8da0.
Any help would be deeply appreciated. I already work in games and am trying to add to my professional skills.
Re: Cannot install Eclipse IDE for C/C++ Developers [message #1808889 is a reply to message #1808885] |
Thu, 04 July 2019 00:21  |
It seems you must have ended up with a corrupted version of this bundle and likely that's cached with a valid timestamp that prevents downloading it again. You could try to delete the .p2/org.eclipse.equinox.p2.core/cache/binary folder from your home folder so that p2 is forced to download a different/new version from the internet when you try again to install.
FUDForum. Page generated in 0.07702 seconds
