MARTE [message #1808061] |
Sat, 15 June 2019 16:14  |
I found that the MARTE feature has been transformed into a Papyrus Component and install it, and I would like to know how to use it.
Is there any explanation how to use it like this; as shown in the example attached? with arrows and labels on it?
https://download.eclipse.org/modeling/mdt/papyrus/components/marte/neon/
I want to understand everything in the properties, palette project explorer.......... etc. all of it
I will use it to make software performance model and then use DICE simulator with it.
please help
Re: MARTE [message #1857432 is a reply to message #1850160] |
Tue, 07 February 2023 09:12   |
I'm looking for an update site containing MARTE to use as target platform. So far I've been using the nightly build (https://ci.eclipse.org/papyrus/job/papyrus-marte-2022-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.marte.p2/target/repository/) but recently my build fails:
[INFO] Fetching org.eclipse.papyrus.marte.static.profile_1.2.3.202204141415.jar from https://ci.eclipse.org/papyrus/job/papyrus-marte-2022-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.marte.p2/target/repository/plugins/ (1.65MB)
[ERROR] An error occurred while transferring artifact canonical: osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415 from repository https://ci.eclipse.org/papyrus/job/papyrus-marte-2022-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.marte.p2/target/repository:
[ERROR] Problems downloading artifact: osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415.:
[ERROR] Error reading signed content:/tmp/signatureFile4946556712229575211.jar
[ERROR] Internal error: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415 into the local Maven repository.See log output for details. An error occurred while processing the signatures for the file: /tmp/signatureFile4946556712229575211.jar: No algorithm found for 1.2.840.113549.1.1.12 -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact osgi.bundle,org.eclipse.papyrus.marte.static.profile,1.2.3.202204141415 into the local Maven repository.See log output for details.
I understand that the problem is about a different RSA signature and it could be solved updating Tycho (currently 1.7.0) to version 2.4.0, but I tried and this involves a waterfall of changes.
I would like to keep the MARTE plugins as they were before mid January.
Is there an update site containing them?
Luca
FUDForum. Page generated in 0.07135 seconds
