ServiceBody does not support `RAW' encoding for OPC UA [message #1808193] |
Tue, 18 June 2019 18:51  |
I am getting an error stating that 'Input type `@OpcUa_Types_Binary.ServiceBody' does not support `RAW' encoding.'
Is it because I upgraded my titan version to 6.5 because it worked totally fine with 6.3 version.
Can someone point out what wrong I am doing? Any help would be really appreciated.
With Regards,
Avdoot
Re: ServiceBody does not support `RAW' encoding for OPC UA [message #1808202 is a reply to message #1808193] |
Wed, 19 June 2019 04:28  |
There was a change in TITAN that made the handling of 'encode' and 'variant' attributes standard-compliant, which caused errors like this when people upgraded their TITAN. To my knowledge that was already in version 6.3, so I'm not sure if this is the case. If it is, then you can return to the old way of handling these attributes with the legacy compiler switch '-e'. If you're using our 'makefilegen' tool, then adding the option '-G' will add this switch to the compiler automatically.
Botond Baranyi
FUDForum. Page generated in 0.05967 seconds
