Mixed model types in GEF [message #180801] |
Tue, 10 May 2005 11:33  |
Originally posted by: freddie_nurke.hotmail.com
Hi folks,
I have two model types in my my application. Most of my graphical stuff
has a base class that allows normal graphical interaction, and some of
my graphical objects contain text. I'm adapting the GEF Text sample
code to create the model for my text, but I don't think it should have
the same base class as the rest of the model -- it behaves differently,
especially in its selection and movement.
getModelChildren should return an object of the same base type as the
parent. Is it possible to have a sub-model on the GEF canvas that
manages itself within the space of an object from the larger model?
Fred
Re: Mixed model types in GEF [message #181589 is a reply to message #180808] |
Tue, 17 May 2005 18:40  |
Got it, it works now. I just overrode the Part's getModelChildren method.
Fred
CL [dnoyeb] Gilbert wrote:
> Fred Nurke wrote:
>> Hi folks,
>> stuff has a base class that allows normal graphical interaction, and
>> some of my graphical objects contain text. I'm adapting the GEF Text
>> sample code to create the model for my text, but I don't think it
>> should have the same base class as the rest of the model -- it behaves
>> differently, especially in its selection and movement.
>> Thanks,
>> Fred
> each model gets wrapped by an editpart by using your editpart factory of
> the editor its being added to. So it does not matter what type of
> models you have, so long as you create an appropriate EditPart for each
> of them.
> You can have children that have children that have children. Nothing
> wrong with that. But typically the parent will handle the layout of its
> children. And still they are all passed through the edit part factory
> of your EditorPart.
> CL
FUDForum. Page generated in 0.07836 seconds
