Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF](Generate EEF Architecture error)
[EEF] [message #1807930] Wed, 12 June 2019 13:54 Go to next message
We have numerous Ecore models that we are using EEF properties view with. We can no longer generate the properties pages. We are using Eclipse 4.11 with EEF 2.1.2 and Extended Editing Framework 1.5.1. When rt-clicking an eefgen file > EEF > Generate EEF Architecture, we get the following error:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '/0/declareEObjectUpdater.1/editionElement'. (file:/C:/Eclipse/eclipse-latest/configuration/org.eclipse.osgi/464/0/.cp/org/eclipse/emf/eef/codegen/widgets/impl/imageviewer/imageViewerControl.emtl, 566, 135)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
	at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:391)
	at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:356)
	at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:233)
	at org.eclipse.acceleo.engine.internal.environment.AcceleoEvaluationEnvironment.loadDynamicModules(AcceleoEvaluationEnvironment.java:829)
	at org.eclipse.acceleo.engine.internal.environment.AcceleoEvaluationEnvironment.mapDynamicOverrides(AcceleoEvaluationEnvironment.java:938)
	at org.eclipse.acceleo.engine.internal.environment.AcceleoEvaluationEnvironment.<init>(AcceleoEvaluationEnvironment.java:173)
	at org.eclipse.acceleo.engine.internal.environment.AcceleoEnvironmentFactory.createEvaluationEnvironment(AcceleoEnvironmentFactory.java:124)
	at org.eclipse.ocl.internal.evaluation.QueryImpl.getEvaluationEnvironment(QueryImpl.java:280)
	at org.eclipse.ocl.ecore.QueryImpl.getEvaluationEnvironment(QueryImpl.java:68)
	at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvaluate(AcceleoEngine.java:353)
	at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate(AcceleoEngine.java:142)
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerateTemplate(AcceleoService.java:984)
	at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:641)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:209)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:172)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:159)
	at org.eclipse.emf.eef.codegen.launcher.EEFLauncher.doGenerate(EEFLauncher.java:232)
	at org.eclipse.emf.eef.codegen.ui.generators.common.GenerateAll.doGenerate(GenerateAll.java:102)
	at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGenerateEEFAction$1.run(AbstractGenerateEEFAction.java:102)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '/0/declareEObjectUpdater.1/editionElement'. (file:/C:/Eclipse/eclipse-latest/configuration/org.eclipse.osgi/464/0/.cp/org/eclipse/emf/eef/codegen/widgets/impl/imageviewer/imageViewerControl.emtl, 566, 135)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1197)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1282)
	at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:746)
	at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:539)
	at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:888)
	at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:824)
	at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
	at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1216)
	at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:635)
	at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:324)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
	at org.eclipse.acceleo.model.mtl.resource.EMtlResourceImpl.doLoad(EMtlResourceImpl.java:93)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1563)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1342)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	... 21 more
I did not find any bug tickets in reference to this.
Re: [EEF] [message #1807946 is a reply to message #1807930] Thu, 13 June 2019 00:48 Go to previous messageGo to next message
See https://www.eclipse.org/forums/index.php/mv/msg/1098273/1806509/#msg_1806509
Use Acceleo 3.7.8. http://download.eclipse.org/acceleo/updates/releases/3.7/R201902261618/?d
Ed Willink
Re: [EEF] [message #1807968 is a reply to message #1807946] Thu, 13 June 2019 08:27 Go to previous message
That worked. Thanks so much.
Previous Topic:EMF Refactor & Modisco Java model
Next Topic:Modeling Symposium @ EclipseCon Europe 2019
Current Time: Sun Jul 20 17:14:39 EDT 2025
Powered by FUDForum. Page generated in 0.03563 seconds
