IDE [message #1807778] |
Sun, 09 June 2019 06:01  |
Be it any programming language, if the Editor or IDE is not user friendly, it becomes very tedious or cumbersome. I have been working on C and C++ for more than a year now. Initially, I started with the Blue (DOS based) screen of Turbo C 2.0 - I used that for around 6 months but did not like it as its editing features are not that good..
Later i started developing on NotePad++ with a command line compiler..
now since 2 months, I have started using Eclipse IDE for C/C++.. at times it is OK.. at times - it behaves very strange..
This time, i have written a 10 line simple program - its working in a command line compiler BCC32, it is also working properly in TurboC 2.0...
but, when i try to compile in Eclipse, it says ----
14:56:55 **** Incremental Build of configuration Debug for project Sea ****
Info: Internal Builder is used for build
gcc -O0 -g3 -Wall -c -fmessage-length=0 -o TheMain.o "..\\TheMain.c"
gcc -o Sea.exe TheMain.o
C:/TDM-GCC-64/bin/../lib/gcc/x86_64-w64-mingw32/5.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot open output file Sea.exe: Permission denied
collect2.exe: error: ld returned 1 exit status
14:56:55 Build Failed. 1 errors, 0 warnings. (took 519ms)
I have tried my luck with many other IDEs [ Devcpp, cygwin, etc ] do not find anyone as comfortable..
Mukesh
FUDForum. Page generated in 0.04338 seconds
