XDCTools documentation [message #1807066] |
Wed, 22 May 2019 02:52  |
I want to combine two TI example projects, specifically UART and PWM related. Obviously, the example projects have conflicting resource configurations, which I would like to resolve via XDCTools/app.cfg adjustments. Specifically, I would like to adapt the Timer configuration, but I find the app.cfg UI in CCS 9 incomprehensible.
Unfortunately, the TI documentation appears to me being a mess of circular references. Is there a current user/reference guide for XDCTools/CCS somewhere available?
Re: XDCTools documentation [message #1807222 is a reply to message #1807150] |
Fri, 24 May 2019 15:23  |
Sasha, thank you for following up on this and your advice. Meanwhile, I came across the "TI-RTOS Kernel (SYS/BIOS) User's Guide", February 2018, Literature Number: SPRUEX3U, which provides the information I was missing on the XDCTools configuration parameters.
In order to understand the philosophy behind the driver libraries, I found following docs valuable:
- TI-RTOS 2.20 User's Guide, June 2016, Literature Number: SPRUHD4M
- TivaWare(tm) Peripheral Driver Library User's Guide, revised July 2016, Literature Number: SPMU298D
- Tiva TM TM4C123GH6PM Microcontroller Data Sheet, 2007-2014, Literature Number: SPMS376E (for my EK-TM4C123GXL)
(the literature number is convenient for retrieval from ti.com)
Unfortunately, TI decided not support TI-RTOS on Hercules devices (I understand the rational, but still unwise in my opionion) which means having to dig into HalCoGen/FreeRTOS for my RM57LX LaunchPad.
FUDForum. Page generated in 0.03390 seconds
