Home » Newcomers » Newcomers » 'building work space ha encountered a problem'
'building work space ha encountered a problem' [message #1807075] Wed, 22 May 2019 04:46 Go to next message
I've installed Eclipse IDE for Java Developers Version: 2019-03 (4.11.0) Build id: 20190314-1200 for windows 64.
When I create a new java project this error appears on the screen:
'building workspace ha encountered a problem'
Errors occurred during the build.
Errors running builder 'Java Builder' on project 'helloworld'.
I tried to set a new workspace and remove and install Eclipse again, but nothing worked so far.
Also...... I am totally new to java programming and not so skilled in programming in general
Re: 'building work space ha encountered a problem' [message #1807158 is a reply to message #1807075] Thu, 23 May 2019 17:14 Go to previous message
Which version of Java is being used to run Eclipse? Does the NullPointerException show up in the logs, and if so, can you share that? https://wiki.eclipse.org/IRC_FAQ#Where_are_Eclipse.27s_log_files_located.3F
Previous Topic:Oxygen and High Sierra
Next Topic:Message: Cannot open Git Upload Pack
Current Time: Sun Jul 20 16:58:28 EDT 2025
Powered by FUDForum. Page generated in 0.07737 seconds
