Home » Modeling » TMF (Xtext) » How to Test custom validation with JUnit
How to Test custom validation with JUnit [message #1806991] Mon, 20 May 2019 14:13 Go to next message
I try to test my validation with JUnit.
class MyDslValidator extends AbstractMyDslValidator {
@Check
def checkPosition(CANSignal can){
if(can.pos < 0 || can.pos > 100){
warning("Position out of Range", MyDslPackage.Literals.CAN_SIGNAL__NAME)
This works so far in the Editor. When I edit a greater Value i get the message, Now I want to make a JUnit test for it and fail. I read some but don't find the correct solution. Eclipse says
org.junit.ComparisonFailure: expected:<E[rror : Position]> but was:<E[xpected WARNING 'Position out of Range' on CANSignal at [-1:-1] but got
WARNING (null) 'Position out of Range' on CANSignal, offset 62, length 8
My TestCode (not complete)
@Test
def void validationTest(){
Position 500
'''.parse.assertPosition("Position")
def void assertPosition(Domainmodel domainmodel, String string){
domainmodel.assertWarning(MyDslPackage.eINSTANCE.CANSignal, "Position out of Range" ,"Error : " + string )
I read in the book of Bettini but don't get it.
How to test it properly? Valid Positions, greater and smaller than the range?
Markus
Re: How to Test custom validation with JUnit [message #1806992 is a reply to message #1806991] Mon, 20 May 2019 14:19 Go to previous messageGo to next message
Am not sure what your actual question is.
Have a look at the signatures of the assert methods and use them
public void assertWarning(org.eclipse.emf.ecore.EObject model,
org.eclipse.emf.ecore.EClass objectType,
java.lang.String code,
java.lang.String... messageParts)
You create the error message without code.
Re: How to Test custom validation with JUnit [message #1807012 is a reply to message #1806992] Tue, 21 May 2019 05:31 Go to previous messageGo to next message
Hi, thanks to your replies. Sometimes I'm confused with this stuff.
I got it, it works now. But another Problem occured.
I try to test the generator. The generator creates two files:
class MyDslGenerator extends AbstractGenerator {
override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
for(e : resource.allContents.toIterable.filter(Domainmodel)){
fsa.generateFile('File1' ,e.compile)}
for(en : resource.allContents.toIterable.filter(Domainmodel)){
fsa.generateFile('File2' ,en.compileTS)}
When I test it with String..assertCompilesTo(String) it throws me error: multiple files are generated.
How can i test one of this files?
Markus
Re: How to Test custom validation with JUnit [message #1807041 is a reply to message #1807012] Tue, 21 May 2019 12:36 Go to previous message
Which assert method so you refer to?
Previous Topic:Formatter problems
Next Topic:How to resolve terminal conflict
Current Time: Sun Jul 20 18:37:36 EDT 2025
Powered by FUDForum. Page generated in 0.03424 seconds
