Home » Modeling » TMF (Xtext) » Sharing xtext generated projects to Git causes errors in ui and ui.tests
Sharing xtext generated projects to Git causes errors in ui and ui.tests [message #1806761] Tue, 14 May 2019 16:25 Go to next message
I'm using xtext 2.17.1 on Eclipse 2019-03 on Linux, and had implemented a simple DSL in a newly created xtext project in a local workspace. I could start a new Eclipse runtime instance to test it. I added a validation rule and some tests and shared the generated projects to Git, and now I can't start the runtime due to errors in ui (and also ui.tests) project.
I've tried building after cleaning all projects as well as, importing the projects into a new workspace but without any luck.
I've pushed the git repo into a local gitlab project and pulled it from a different machine so I think that the Git repo itself is OK.
My .gitignore file is:
.settings
tmp
bin
target
generated
generated-sources
src-gen
xtend-gen
model
*.xml_gen
I've included the top few errors in the footer. I think the last error may point to the root cause which is the failure to connect to SOCKS proxy to check maven plugin.
However, I can connect to the SOCKS proxy host and port OK from the command
line with "nc -vz" without any problems. So I'm lost as to the next steps, and would
really appreciate any help!
Ajit
Description	Resource	Path	Location	Type
- cannot be resolved.	ServerLauncher.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 42 /com.intel.dml.web/src/com/intel/dml/web/ServerLauncher.xtend	Xtend Problem
AbstractDMLWebModule cannot be resolved to a type.	DMLWebModule.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 10 /com.intel.dml.web/src/com/intel/dml/web/DMLWebModule.xtend	Xtend Problem
AnnotationConfiguration cannot be resolved.	ServerLauncher.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 27 /com.intel.dml.web/src/com/intel/dml/web/ServerLauncher.xtend	Xtend Problem
com.google.inject.Guice cannot be resolved to a type.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 6 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
com.google.inject.Injector cannot be resolved to a type.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 7 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
com.intel.dml.DMLRuntimeModule cannot be resolved to a type.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 8 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
com.intel.dml.DMLStandaloneSetup cannot be resolved to a type.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 9 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
com.intel.dml.ide.DMLIdeModule cannot be resolved to a type.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 10 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
Couldn't find a JDK 1.5 or higher on the project's classpath.	DMLServlet.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 4 /com.intel.dml.web/src/com/intel/dml/web/DMLServlet.xtend	Xtend Problem
Couldn't find a JDK 1.5 or higher on the project's classpath.	DMLWebModule.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 4 /com.intel.dml.web/src/com/intel/dml/web/DMLWebModule.xtend	Xtend Problem
Couldn't find a JDK 1.5 or higher on the project's classpath.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 4 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
Couldn't find a JDK 1.5 or higher on the project's classpath.	ServerLauncher.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 4 /com.intel.dml.web/src/com/intel/dml/web/ServerLauncher.xtend	Xtend Problem
DisposableRegistry cannot be resolved to a type.	DMLServlet.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 16 /com.intel.dml.web/src/com/intel/dml/web/DMLServlet.xtend	Xtend Problem
DMLIdeModule cannot be resolved.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 19 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
DMLRuntimeModule cannot be resolved.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 19 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
DMLStandaloneSetup cannot be resolved to a type.	DMLWebSetup.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 16 /com.intel.dml.web/src/com/intel/dml/web/DMLWebSetup.xtend	Xtend Problem
Error resolving version for plugin 'org.apache.maven.plugins:maven-site-plugin' from the repositories [local (/home/ajit/.m2/repository), codehaus-snapshots (http://nexus.codehaus.org/snapshots/), central (https://repo.maven.apache.org/maven2)]: Plugin not found in any plugin repository	pom.xml	/com.intel.dml	line 1	Maven pom Loading Problem
Error resolving version for plugin 'org.apache.maven.plugins:maven-site-plugin' from the repositories [local (/home/ajit/.m2/repository), codehaus-snapshots (http://nexus.codehaus.org/snapshots/), central (https://repo.maven.apache.org/maven2)]: Plugin not found in any plugin repository	pom.xml	/com.intel.dml.feature	line 1	Maven pom Loading Problem
Error resolving version for plugin 'org.apache.maven.plugins:maven-site-plugin' from the repositories [local (/home/ajit/.m2/repository), codehaus-snapshots (http://nexus.codehaus.org/snapshots/), central (https://repo.maven.apache.org/maven2)]: Plugin not found in any plugin repository	pom.xml	/com.intel.dml.ide	line 1	Maven pom Loading Problem
Error resolving version for plugin 'org.apache.maven.plugins:maven-site-plugin' from the repositories [local (/home/ajit/.m2/repository), codehaus-snapshots (http://nexus.codehaus.org/snapshots/), central (https://repo.maven.apache.org/maven2)]: Plugin not found in any plugin repository	pom.xml	/com.intel.dml.tests	line 1	Maven pom Loading Problem
Error resolving version for plugin 'org.apache.maven.plugins:maven-site-plugin' from the repositories [local (/home/ajit/.m2/repository), codehaus-snapshots (http://nexus.codehaus.org/snapshots/), central (https://repo.maven.apache.org/maven2)]: Plugin not found in any plugin repository	pom.xml	/com.intel.dml.ui	line 1	Maven pom Loading Problem
Exception cannot be resolved to a type.	ServerLauncher.xtend	/com.intel.dml.web/src/com/intel/dml/web	line: 49 /com.intel.dml.web/src/com/intel/dml/web/ServerLauncher.xtend	Xtend Problem
Failure to transfer org.eclipse.tycho:tycho-source-plugin:pom:1.3.0 from https://repo.maven.apache.org/maven2 was cached in the local repository, resolution will not be reattempted until the update interval of central has elapsed or updates are forced. Original error: Could not transfer artifact org.eclipse.tycho:tycho-source-plugin:pom:1.3.0 from/to central (https://repo.maven.apache.org/maven2): Can't connect to SOCKS proxy:Connection refused (Connection refused)	pom.xml	/com.intel.dml.parent	line 1	Maven pom Loading Problem
Re: Sharing xtext generated projects to Git causes errors in ui and ui.tests [message #1806763 is a reply to message #1806761] Tue, 14 May 2019 17:40 Go to previous message
I stumbled upon a work-around: I deleted the runtime Eclipse workspace before running it again and now I get errors only in the ui.tests project (which I've not touched at all).
Previous Topic:Serializing Instances based on the Domainmodel (15 minutes tutorial)
Next Topic:Outline to be refreshed after the code refactoring
Current Time: Sun Jul 20 19:47:47 EDT 2025
Powered by FUDForum. Page generated in 0.02857 seconds
