TFS Plugin on OSX [message #1805609] |
Thu, 18 April 2019 12:10  |
I'm a new Eclipse user looking to hook up Eclipse with our institutional TFS/Git environment. I'm running Mac OSX (10.12.6) and Eclipse (2019-03 (4.11.0)) and was looking to install the MS TFS plugin, using the following various instructions, e.g., via Marketplace, via New Software and local installation from a Zip file (TFSEclipsePlugin-UpdateSiteArchive-14.134.0.zip). All installations ran without a hitch.
Everything goes as advertised, but when I restart as directed, I am never able to get the plugin to appear either in a View or a Perspective. When I try to reinstall, it tells me it is already installed.
If I look in plugs tab of my workspace, I can see something like 29 TFS items installed. I also see "Team Explorer" under the software tab under "About Eclipse/Installation details" - but it doesn't appear under the plug-ins tab in that dialog.
I've tried installing through Marketplace, locally with a zip file and via "New software" - all installations run with no errors, but the plugin just never appears as a View or Perspective.
Any suggestions on getting this into a useable state (i.e., as a view or perspective) would be greatly appreciated!
Thanks in advance, Al
P.S. Actually I finally found the error log, and there were indeed errors. Each component of the TFS Plug-in had a line similar to this one:
!MESSAGE Failed to find a configured bundleInfo for: [R]com.microsoft.tfs.checkinpolicies 14.134.0.201804261732.
[Updated on: Thu, 18 April 2019 15:11] by Moderator
Re: TFS Plugin on OSX [message #1859877 is a reply to message #1805609] |
Mon, 03 July 2023 10:19  |
Have you got any solution regarding your problem? I am having a similar error while installing a custom made plugin to eclipse MAT.
Error:
org.eclipse.equinox.p2.touchpoint.eclipse
Warning
Failed to find a configured bundleInfo for: [R]<Plugin_Name>
FUDForum. Page generated in 0.10555 seconds
