Home » Eclipse Projects » Sirius » Create an own node type
Create an own node type [message #1805551] Wed, 17 April 2019 04:32 Go to next message
is there any possibility to create an own node (not a style) like a "Sub Node" for a "Container" or does a tutorial exist for this?
Marvin
Re: Create an own node type [message #1805552 is a reply to message #1805551] Wed, 17 April 2019 04:44 Go to previous messageGo to next message
Hello Marvin,
What is your need exactly?
I'm not sure to understand what you want.
It's possible to define a new dialect with Sirius using the Sirius extension point but I'm not sure that correspond to your need.
Re: Create an own node type [message #1805554 is a reply to message #1805552] Wed, 17 April 2019 07:07 Go to previous messageGo to next message
Hi Julien,
i have still the same problem which I posted in another topic (https://www.eclipse.org/forums/index.php/t/1098363/). There was no reply after my last post. Therefore, I think this problem can not be solved by the Semantic Candidates Expression. My idea is to set up a new node type which provides the needed information for solving the problem.
Marvin
Re: Create an own node type [message #1805591 is a reply to message #1805554] Thu, 18 April 2019 05:29 Go to previous message
Hi Marvin,
As you have 2 cases you must indeed define 2 mappings. You must use the precondition expression for the 2 mappings.
The semantic candidates expression correspond for Sirius at : "How, from my context I can retrieve the elements corresponding to my Domain Class"
The precondition expression is "From my context, I must applied this condition"
Previous Topic:Show subnodes(children) of Candiadates in SelectionWizard
Next Topic:Add viewpoint to Sirius server and use it
Current Time: Sun Jul 20 17:52:44 EDT 2025
Powered by FUDForum. Page generated in 0.03508 seconds
