Home » Newcomers » Newcomers » Launch an eclipse application missing in version 4.9(In eclipse version 3.5.2 there was a option under workbench of testing where launch eclipse was there. It is missing in new version 4.9)
Launch an eclipse application missing in version 4.9 [message #1802397] Fri, 08 February 2019 02:36 Go to next message
Hi Team,
I am not getting option of launch an eclipse application in eclipse version 4.9 while the same was available in previous version of 3.5.2.
I am not able to get project celia of Cisco due to this. Also my reports are stucked in between due to this issue which is affecting my agreement with client.
Can you please have a look into and confirm how will I get this option in new version.
Thanks & Regards
Nishit Garg
+91-9811975586
Re: Launch an eclipse application missing in version 4.9 [message #1802613 is a reply to message #1802397] Tue, 12 February 2019 14:29 Go to previous messageGo to next message
Are you sure? You seem to have the plug-in manifest editor open, so the option should be there in the launch configuration dialog, just as before.
Re: Launch an eclipse application missing in version 4.9 [message #1802666 is a reply to message #1802613] Wed, 13 February 2019 10:43 Go to previous messageGo to next message
I am not able to see Project Celia which is under Testing and appears when we click on Launch an eclipse application.
In new version option of launch an eclipse application is missing. I have attached screenshot. Can you please help me.
Re: Launch an eclipse application missing in version 4.9 [message #1805259 is a reply to message #1802666] Wed, 10 April 2019 09:47 Go to previous messageGo to next message
I was able to run my inputs through import in project celia from Eclipse application version 3.5.2. Since the upgrade of this to 4.9 I am unable to do this activity due to missing project celia.
Can anyone help from eclipse tools support team. This is affecting my scheduled requirement and affecting capacity reporting.
Re: Launch an eclipse application missing in version 4.9 [message #1805362 is a reply to message #1805259] Fri, 12 April 2019 11:53 Go to previous messageGo to next message
Can you show 3.5 and 4.9 side by side and highlight what is missing in 4.9? Right now it looks like something you'll need to talk to Cisco about, assuming it's not just a configuration problem on your specific machine.
Re: Launch an eclipse application missing in version 4.9 [message #1805443 is a reply to message #1805362] Mon, 15 April 2019 07:09 Go to previous messageGo to next message
Hi Nitin,
Thanks for your response. I have attached screenshots taken in both 3.5 and 4.9 version. You can see clearly that Under plugin.xml Testing option is present in version 3.5 while the same is missing under version 4.9
Can you please have a look and confirm where can I find this in new version of 4.9
Re: Launch an eclipse application missing in version 4.9 [message #1805446 is a reply to message #1805443] Mon, 15 April 2019 07:46 Go to previous messageGo to next message
In the second case, you're opening it with the XML editor, in the first case, you've opened it with the Plug-in Manifest editor. Is that option available on the context menu's Open With -> choices? If not, you don't have PDE installed...
[Updated on: Mon, 15 April 2019 10:10] by Moderator
Re: Launch an eclipse application missing in version 4.9 [message #1805548 is a reply to message #1805446] Wed, 17 April 2019 03:49 Go to previous messageGo to next message
Can you please help me where can I find link to install Eclipse PDE. I have installed Java version 12 in system still it is not showing option of testing under plugin.xml.
I have attached screenshot for the same as well.
Can it be possible we can coordinate on call. My contact number is +919811975586.
Nishit Garg
Re: Launch an eclipse application missing in version 4.9 [message #1805577 is a reply to message #1805548] Wed, 17 April 2019 11:25 Go to previous message
Generally you can use Help -> Install New Software, use the URL that corresponds to the version of Eclipse you've installed, e.g., http://download.eclipse.org/releases/2019-03 (it will probably be in the list) and search for "Eclipse Plug-in Development" in the search field. If you're doing plug-in development, you should probably have installed "Eclipse IDE for Eclipse Committers".
Previous Topic:Trouble launching Eclipse Help System from program files dir
Next Topic: The installer the eclipse!
Current Time: Sat Jul 19 14:43:03 EDT 2025
Powered by FUDForum. Page generated in 0.09821 seconds
