Home » Language IDEs » Java Development Tools (JDT) » Test discovery very slow with JDK11(JDK11+eclipse+junit launcher)
Test discovery very slow with JDK11 [message #1805418] Mon, 15 April 2019 03:20 Go to next message
we have a project with about 5000 JUnit testcases spread over 700 classes.
When launching the entire test suite in Eclipse 2018-12 with an Openjdk11, the launch takes approximately 60 seconds (which is about as long as the actual test run). It seems to stall on "creating class hierarchy (65%)" in the progress window. We've never seen this until switching over to Java 11. With previous versions of Eclipse and Java 8, this takes about 5 seconds.
I managed to use a JDK8 with 2018-12 as well and then it is fast again, so I don't think the problem lies in Eclipse itself but rather some interaction between Eclipse and JDK11. All this on Windows, I have not tried it in Linux.
All the project's users are seeing the same thing, so it isn't a local problem.
Has anyone else seen this or have a way around it?
TIA,
Chris
Re: Test discovery very slow with JDK11 [message #1805420 is a reply to message #1805418] Mon, 15 April 2019 03:34 Go to previous messageGo to next message
Looks like https://bugs.eclipse.org/bugs/show_bug.cgi?id=513334. Please add your observation in the bug report.
Re: Test discovery very slow with JDK11 [message #1805425 is a reply to message #1805420] Mon, 15 April 2019 04:43 Go to previous message
Added a comment on that tracker. Not sure if it is the same issue or not but at least it has the same symptoms.
Previous Topic:This code confuses eclipse
Next Topic:'Problem Occurred' when suggestions come up
Current Time: Sat Jul 19 19:15:05 EDT 2025
Powered by FUDForum. Page generated in 0.24941 seconds
