Home » Eclipse Projects » Sirius » Conditional style in tree description
Conditional style in tree description [message #1805151] Mon, 08 April 2019 09:32 Go to next message
I am trying to create a new tree view based on sirius tree description.
So far I have successfully been able to define the content of the tree, and to define some drag & drop tools.
However, I do not achieve to apply conditional style on the tree.
I have declared a conditional style under a tree element.
In order to know if the conditional style has to be applied, I need to get the DTreeItem in order to know where the semantic element is represented in the tree.
The predicate expression I use is: "<% $view.isMissingFromInterfaces() %>" and I have defined the associated Java function:
public boolean isMissingFromInterfaces (DTreeItem item) { ... }
The result is that my Java function is never called...
It seems like the variable "view" is use is not recognized.
Any idea?
Re: Conditional style in tree description [message #1805170 is a reply to message #1805151] Tue, 09 April 2019 04:01 Go to previous messageGo to next message
Have you tried "var:" with ctrl+space for auto-completion to see available variables? The var interpreter is an optimized interpreter for quick access to variable. The view variable should be available for in predicate expression.
I see that you use an Acceleo2 expression (query legacy). Have you tried with an AQL expression?
Florian
Re: Conditional style in tree description [message #1805172 is a reply to message #1805170] Tue, 09 April 2019 04:44 Go to previous messageGo to next message
Hello Florian,
Thank you for your quick answer.
I am not familiar with AQL expression. Could you help me translate my expression in AQL ?
BTW, when using var + auto-completion, the variable "view" is indeed listed...
Re: Conditional style in tree description [message #1805174 is a reply to message #1805172] Tue, 09 April 2019 05:16 Go to previous messageGo to next message
Moreover, when I check the variables available from the field "Label Expression" of the style itself, I have:
- self
- diagram: [diagram.DSemanticDiagram]
- view: [diagram.DDiagramElement]
(either from info help or from auto-completion)
Isn't there an issue in the definition of the variables?
I am defining a tree and not a diagram!
Re: Conditional style in tree description [message #1805176 is a reply to message #1805174] Tue, 09 April 2019 05:32 Go to previous messageGo to next message
About the label expression, that sounds as a bug. The problem could be a wrong auto-completion documentation. In that case, it would be interesting to see with a Java service the real type of the "view" variable for instance.
About AQL expression, you can define them by using the aql: interpreter. Your expression will be "aql:view.isMissingFromInterfaces()".
You can find documentation about AQL expressions in this page[1] and a detailed documentation here[2].
Florian
[1] https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#aql
[2] https://www.eclipse.org/acceleo/documentation/aql.html
Re: Conditional style in tree description [message #1805177 is a reply to message #1805176] Tue, 09 April 2019 05:40 Go to previous messageGo to next message
I have tried the aql expression. The result is the same (the java service is not called).
How could I check if there is an error in the definition of the auto-completion documentation?
How to use this Java service you are talking about?
Re: Conditional style in tree description [message #1805224 is a reply to message #1805177] Wed, 10 April 2019 04:59 Go to previous message
I have done a debug session and the only available variable is "self" (so the semantic element in that case). The "view" is available in the context of a diagramDescription but not in a treeDescription. That's a bug. Do not hesitate to raise a bugzilla about this issue[1]
About your initial need, conditional style are designed to be applied on the semantic model but not really to depend on the graphical state.
Florian
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Previous Topic:Element Creation Tool doesn't work
Next Topic:Use a List of eObject in a table
Current Time: Sat Jul 19 23:37:49 EDT 2025
Powered by FUDForum. Page generated in 0.05786 seconds
