Home » Modeling » GMF (Graphical Modeling Framework) » Connections behavior
Connections behavior [message #180456] Wed, 02 April 2008 10:16 Go to next message
Two questions about connections:
1)
I've got two nodes A and B and A can point to B. (A -> B). To create a
connection we need with GMF to drag and drop from A to B. Is it possible
to also have a connection from A to B when dragging from B to A ?
2)
Instead of dragging and dropping the connection, I would like to click
on A, then I obtain a dangling connection, and then I click on B to
perform the connection. How can I do that?
Thanks in advance.
Re: Connections behavior [message #180482 is a reply to message #180456] Wed, 02 April 2008 10:19 Go to previous messageGo to next message
This is essentially what the connection handles do. Are they not
sufficient?
- Cherie
Youmm P. wrote:
> Hello,
> 1)
> 2)
> Thanks in advance.
Re: Connections behavior [message #180500 is a reply to message #180482] Wed, 02 April 2008 10:54 Go to previous messageGo to next message
> sufficient?
Not really, I need to base the behavior on a previous editor.
I would like to have like the connection handles, but without keeping
the left mouse button pressed, and this dangling connection would be
created by clicking on the node with a button from the palette.
And only one button. If I have only a directed reference between A and
B, I don't want the user to select A then B. Selecting B and then A
should be fine.
Re: Connections behavior [message #180507 is a reply to message #180482] Wed, 02 April 2008 10:54 Go to previous messageGo to next message
> sufficient?
should be fine.
Re: Connections behavior [message #180662 is a reply to message #180456] Thu, 03 April 2008 03:47 Go to previous messageGo to next message
Ad 1)
Yes, that's possible. Just add a second link mapping and switch
source/target feature. In case you are using an EReference, use the
opposite EReference.
Ad 2)
I'd recommend to have a look at GEF then. Sounds rather complicated and
I doubt that the GMF runtime will offer you much help.
Jan
Youmm P. schrieb:
> Hello,
> 1)
> 2)
> Thanks in advance.
Re: Connections behavior [message #180676 is a reply to message #180662] Thu, 03 April 2008 04:09 Go to previous message
The problem is that my reference is directed. I don't have any opposite
EReference, can we do that without?
Previous Topic:link between subtypes of an element. Does not work with connection handles. Possible Bug.
Next Topic:the Problem of Compartment's compartment's Layout! GMF's Bug????
Current Time: Sun Jul 20 08:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.03363 seconds
