Home » Newcomers » Newcomers » code segment has wrong length
code segment has wrong length [message #180416] Wed, 15 November 2006 14:45 Go to next message
Originally posted by: mika.villafinn.net
I hope this is the right group.
I have a problem and I have asked about it from JFreeChart forums and I
get cople of answers but it didn't help so I ask here.
When I launch my application from eclipse it works fine but when I
create jar file and launch it - it starts and everything else works but
charts which are created with JFreeChart-packages.
I put the error here what it gives :
Exception in thread "AWT-EventQueue-0" java.lang.ClassFormatError: Code
segment
has wrong length in class file org/jfree/chart/ChartFactory
Do somebody know what is the problem and if someone knows it
.....please,please tell it to me.
Mika Suomi
mika@villafinn.net
Re: code segment has wrong length [message #180890 is a reply to message #180416] Sun, 19 November 2006 06:09 Go to previous message
> segment
This error suggests that there are problems in the compilation process
of class org.jfree.chart.ChartFactory.
1. Did you compile this class from source code or using it as a binary
you downloaded from somewhere? If this is the case, then contact the
vendor of this class.
2. If you did compile from source - did you use the Eclipse compiler to
create your JAR file(s), or an external compiler (some version of
javac...) launched from a build script (such as Ant)? If you used the
Eclipse compiler, then you may have found a bug in the Eclipse Java
compiler (unlikely). If you used an external compiler, try switching to
another one (a newer version?) and check again.
Another possible cause for this problem is that the binary code of
org.jfree.chart.ChartFactory was modified during execution by a tool
such as a profiler or a debugger (a technique known as Byte Code
Instrumentation). Are you using such a tool? If so, contact the tool vendor.
HTH!
Asaf
Asaf Yaffe
Eclipse TPTP Committer, Platform Project (JVMTI Profiler)
Previous Topic:where are codes generated by WTP tools
Next Topic:JFace/SWT
Current Time: Sat Jul 19 17:15:33 EDT 2025
Powered by FUDForum. Page generated in 0.07125 seconds
