[XCore] XcoreLang.xcore content is not allowed in Prolog [message #1803664] |
Wed, 06 March 2019 07:50  |
NOTE: This was wrongly published on TMF Xtext Forum. (https://www.eclipse.org/forums/index.php/t/1097920/).
ORIGINAL MESSAGE
I browsed the newsgroups and web to find hints about how to solve this issue. This happens when I create and execute a standalone RCP. I already got a similar problem long time ago but I do not remember how I solved it. I am pretty sure there are missing dependencies in the RCP product. Despite this exception, the system works as usual. If someone has an idea, it would be really appreciated.
Here is the detail of the exception.
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: platform:/plugin/or
g.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore; systemId: platform:/plugin/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore; lineNumber: 1;
columnNumber: 1; Content is not allowed in prolog.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor$Dynamic.getEPackage(RegistryReader.java:250)
... 42 more
Caused by: org.xml.sax.SAXParseExceptionpublicId: platform:/plugin/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore; systemId: platform:/plugin/o
rg.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:441)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1436)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:999)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:333)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1563)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1342)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 44 more
Ed's Merks Response:
Normally a *.xcore resource should be loaded using an XcoreResource but that's created by the injector and is registered via the runtime module. I'm not sure your overall context where this happens. I've not seen this problem before. Something must be demand loading the registered package, but something that requires this should be loading using an Xtext resource set....
[Updated on: Wed, 06 March 2019 07:52] by Moderator
FUDForum. Page generated in 0.07802 seconds
