Home » Newcomers » Newcomers » How to upgrade Eclipse?
How to upgrade Eclipse? [message #1802778] Fri, 15 February 2019 09:56 Go to next message
I'm trying to follow the steps from this tutorial in Eclipse 2018-09.
After pasting URL I can't clikc "OK" like it is described - I can feel also the name of the site and click "Add".
Then I'm supposed to go to "Help > Check for Updates".
But what I see is a list of available software from added site... and I don't know what to do ;)
Should I mark all of them? It doesn't look like Eclipse itself upgrade.
I know I can always install from scratch, but I wanted to upgrade this instance.
Thanks in advance.
Re: How to upgrade Eclipse? [message #1802915 is a reply to message #1802778] Mon, 18 February 2019 18:56 Go to previous messageGo to next message
Which version are you on now? What site URL are you adding?
Re: How to upgrade Eclipse? [message #1802928 is a reply to message #1802915] Tue, 19 February 2019 03:34 Go to previous messageGo to next message
Nitin - I was on 2018-09 version, like I wrote. I was adding the http://download.eclipse.org/releases/2018-12/ update site from the example.
Re: How to upgrade Eclipse? [message #1802953 is a reply to message #1802778] Tue, 19 February 2019 10:15 Go to previous messageGo to next message
Just to make sure, did you accidentally hit the Install New Software menu item instead? Checking for updates should either throw up a progress dialog or show that it's checking your sites for updates in the Progress view, and when done open an installation dialog with the updates it found.
Re: How to upgrade Eclipse? [message #1802956 is a reply to message #1802953] Tue, 19 February 2019 10:51 Go to previous message
Yeah, I think so ;)
Thank you.
Previous Topic:Eclipse installation
Next Topic:Workbench could not be found in the registry
Current Time: Sun Jul 20 13:24:44 EDT 2025
Powered by FUDForum. Page generated in 0.09632 seconds
