Saving as jpeg!!! [message #180291] |
Wed, 04 May 2005 05:08  |
Originally posted by: gautamn.iitk.ac.in
i am developing a pluign for eclipse to make architecture diagrams. I
want to save my diagram files as jpeg,gif etc. How to do that???My save as
code is like this:
* @see org.eclipse.ui.ISaveablePart#doSaveAs()
public void doSaveAs() {// Show a SaveAs dialog
Shell shell = getSite().getWorkbenchWindow().getShell();
SaveAsDialog dialog = new SaveAsDialog(shell);
dialog.setOriginalFile(((IFileEditorInput) getEditorInput()).getFile());
dialog.open();
IPath path = dialog.getResult();
if (path != null) {
// try to save the editor's contents under a different file name
final IFile file =
ResourcesPlugin.getWorkspace().getRoot().getFile(path);
try {
new ProgressMonitorDialog(shell).run(
false, // don't fork
false, // not cancelable
new WorkspaceModifyOperation() { // run this operation
public void execute(final IProgressMonitor monitor) {
try {
ByteArrayOutputStream out = new ByteArrayOutputStream();
createOutputStream(out);
file.create(
new ByteArrayInputStream(out.toByteArray()), // contents
true, // keep saving, even if IFile is out of sync with the
Workspace
monitor); // progress monitor
catch (CoreException ce) { ce.printStackTrace(); }
catch (IOException ioe) { ioe.printStackTrace(); }
// set input to the new file
setInput(new FileEditorInput(file));
getCommandStack().markSaveLocation();
catch (InterruptedException ie) {
// should not happen, since the monitor dialog is not cancelable
ie.printStackTrace();
catch (InvocationTargetException ite) {
ite.printStackTrace();
} // if
private void createOutputStream(OutputStream os)
throws IOException {
ObjectOutputStream oos = new ObjectOutputStream(os);
oos.writeObject(getModel());
oos.close();
Nitin Gautam.
Re: Saving as jpeg!!! [message #180301 is a reply to message #180291] |
Wed, 04 May 2005 07:46   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I would look at the print features for this. It should give you an idea
of how to capture the diagram graphically.
CL
Nitin Gautam wrote:
> Hi, i am developing a pluign for eclipse to make architecture diagrams.
> I want to save my diagram files as jpeg,gif etc. How to do that???My
> save as code is like this:
> dialog.open();
> if (path != null) {
> name
> final IFile file =
> try {
> operation
> monitor) {
> try {
> file.create(
> new
> IFile is out of sync with the Workspace
> ioe.printStackTrace(); } }
> cancelable
> ie.printStackTrace(); }
> ite.printStackTrace(); }
> } // if
> private void createOutputStream(OutputStream os) throws
> IOException {
> oos.close();
> Regards,
> Nitin Gautam.
Re: implementing multiple connection types [message #180317 is a reply to message #180309] |
Wed, 04 May 2005 08:57   |
benedict heal wrote:
> I have an editor in which I want to have two types of connection - e.g.
> 'childof' and 'spouseof'.
> What is the recommended way of handling this?
> Should I have
> - two palette tools, two requests, two commands
> or
> - 2 tools, and a single request with a 'connection type' field
> or
> - something else.
> do
> The GEF sample shape editor solves a similar problem of passing a line
> style by having a single request type, and fiddling with
> request.getNewObjectType() to return an Integer line style, but there's
> a comment in the code suggesting the author isn't v. happy with this.
> thanks,
> Benedict
depends on how different the two types behave. is the method of
creation exactly the same? if so just use a type field.
All my various shapes use the same tool to create them, since they are
created by the same technique.
So 1 tool, 2 instances of the tool, but different types.
I go for multiple requests as well since you never know if you want to
make them more different at some point.
CL
Re: Saving as jpeg!!! [message #180396 is a reply to message #180291] |
Wed, 04 May 2005 17:17   |
Well, i got curious and dug around a bit. I found an old post in the
archive about the same thing. The subject is "Can i capture the snapshot
of the editor in a JPEG file?".
I tried the code suggested in this post and it worked, sort of. I had to
tweek it a bit to get the result i wanted. I'm not claiming that this is
the best way to do it, but it serves my purpose for now. The code is given
below. Also, below the code i have listed the changes i made to the
original code.
public Image createScreenshot(String fileName) {
Image im = null;
ScalableFreeformRootEditPart editPart = (ScalableFreeformRootEditPart)
getGraphicalViewer().
getContents().getRoot();
LayerManager lm =
(LayerManager)getGraphicalViewer().getEditPartRegistry().get (LayerManager.ID);
IFigure f = lm.getLayer(LayerConstants.PRINTABLE_LAYERS);
Rectangle r = f.getBounds();
// getting zoom value - for scaling translations
double zoom = editPart.getZoomManager().getZoom();
zoom = 1 / zoom;
// viewport which displays my diagram
Viewport viewer = (Viewport)editPart.getFigure();
// margin
int MARGIN = 10;
// my diagram width - using for image width
int imageWidth = r.width;
// my diagram height - using for image height
int imageHeight = r.height;
// scaling image - using diagram width and height multiplied by zoom
// value and adding margins
int imageWidthScaled = (int) (imageWidth*zoom) + 2 * (int)(MARGIN*zoom);
int imageHeightScaled = (int) (imageHeight*zoom) + 2 *
(int)(MARGIN*zoom);
// creating new Image
im = new Image(Display.getDefault(), imageWidthScaled,
imageHeightScaled);
GC gc = new GC(im);
SWTGraphics g = new SWTGraphics(gc);
// paint contents on my Image
viewer.paint(g);
// we do not need g and gc anymore
g.dispose();
gc.dispose();
// saving an image to the disk
try {
ImageLoader loader = new ImageLoader();
loader.data = new ImageData[1];
loader.data[0] = im.getImageData();
loader.save(fileName, SWT.IMAGE_JPEG);
catch (Exception e) {
return im;
Problems in the original:
1. It uses ScalableFreeformRootEditPart's getFigure() method which returns
a Viewport to determine the contents to be saved. This will give you only
that part of the diagram that's within the viewport. Evrything outside
will not be saved. So, i used
LayerManager lm =
(LayerManager)getGraphicalViewer).getEditPartRegistry().get( LayerManager.ID);
This gives the ENITRE diagram. and i can get the size directly from this
figure.
2. it does some translations of the image. i'm not sure of its purpose. In
fact it messed up my view on the editor. So, i took it
out completely.
Sapna
Re: Saving as jpeg!!! [message #180442 is a reply to message #180435] |
Thu, 05 May 2005 04:38   |
in my diagram editor that I created using GEF and Draw2d, I just want
to add a fuctionality that a particular diagram can also be saved in
various formats that an image viewer can open. For this reason I want code
for saving the file generated by Eclipse in an image file format. I used
the specified code and it was giving errors. Can u help in sorting out the
problem???
Nitin Gautam.
My save code is:
ObjectOutputStream objectOut = new ObjectOutputStream(out);
objectOut.writeObject(model);
objectOut.close();
IFile file = ((IFileEditorInput) getEditorInput()).getFile();
file.setContents(new ByteArrayInputStream(out.toByteArray()), true,
false, monitor);
out.close();
and save as code:
dialog.open();
IFigure figure =
((AbstractGraphicalEditPart)getGraphicalViewer().getRootEdit Part()).getFigure();
String desn="";
if (path != null) {
final IFile file =
try {
try {
file.create(
Workspace
} // if
oos.close();
Re: Saving as jpeg!!! [message #180492 is a reply to message #180484] |
Fri, 06 May 2005 02:03  |
Originally posted by: wjancz.\/\/asko.pl(change \/\/ with w)
> thanks its working fine now...I will discuss other issues of my editor
> soon..
> Regards,
> Nitin Gautam.
BTW:
It should be done as Export not as Save option.
Saving is saving a model....
...::WojT::..
FUDForum. Page generated in 0.06146 seconds
