Home » Eclipse Projects » Eclipse 4 » Error with PlatformUI.createAndRunWorkbench method
Error with PlatformUI.createAndRunWorkbench method [message #1786943] Wed, 16 May 2018 03:48 Go to next message
I'm building an e3 rcp with e4 on top of it in compatibility mode.
The application is launchable but i have an error in Application.java
Here is the code of the start method (it's where the error is) :
public Object start(IApplicationContext context) throws Exception {
		String oclDelegateURI = OCLConstants.OCL_DELEGATE_URI;
		EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI,
				new OCLInvocationDelegateFactory.Global());
		EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI,
				new OCLSettingDelegateFactory.Global());
		EValidator.ValidationDelegate.Registry.INSTANCE.put(oclDelegateURI, new OCLValidationDelegateFactory.Global());
		WorkbenchAdvisor workbenchAdvisor = new DedalEditorAdvisor();
		Display display = PlatformUI.createDisplay();
		try {
			int returnCode = PlatformUI.createAndRunWorkbench(display, workbenchAdvisor);
			if (returnCode == PlatformUI.RETURN_RESTART) {
				return IApplication.EXIT_RESTART;
			} else {
				return IApplication.EXIT_OK;
		} finally {
			display.dispose();
And here is the console log :
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/Context/context/SET] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@4bb1b96b (elementId: org.eclipse.ui.navigator.ProjectExplorer, tags: [View, categoryTag:General], contributorURI: platform:/plugin/fr.ema.dedal.rcp) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView, object: null, context: PartImpl (org.eclipse.ui.navigator.ProjectExplorer) Context, variables: null, label: Project Explorer, iconURI: platform:/plugin/org.eclipse.ui.navigator.resources//icons/full/eview16/resource_persp.gif, tooltip: null, dirty: false, closeable: false, description: null), Widget=null, org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@4bb1b96b (elementId: org.eclipse.ui.navigator.ProjectExplorer, tags: [View, categoryTag:General], contributorURI: platform:/plugin/fr.ema.dedal.rcp) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView, object: null, context: PartImpl (org.eclipse.ui.navigator.ProjectExplorer) Context, variables: null, label: Project Explorer, iconURI: platform:/plugin/org.eclipse.ui.navigator.resources//icons/full/eview16/resource_persp.gif, tooltip: null, dirty: false, closeable: false, description: null), AttName=context, EventType=SET, Widget=null, NewValue=PartImpl (org.eclipse.ui.navigator.ProjectExplorer) Context}, AttName=context, NewValue=PartImpl (org.eclipse.ui.navigator.ProjectExplorer) Context, EventType=SET} to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@484a5ddd
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException: URI is not absolute
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:990)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:91)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
	at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1494)
	at org.eclipse.ui.internal.Workbench.openWorkbenchWindow(Workbench.java:2571)
	at org.eclipse.ui.internal.Workbench.getWorkbenchPage(Workbench.java:2016)
	at org.eclipse.ui.internal.Workbench.setReference(Workbench.java:2064)
	at org.eclipse.ui.internal.Workbench.lambda$11(Workbench.java:1954)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4889)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setContext(PartImpl.java:443)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:636)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:546)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:530)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:992)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:661)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:767)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:738)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:716)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1293)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.lambda$0(LazyStackRenderer.java:68)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:102)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:679)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:137)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:675)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:79)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:61)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:704)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1076)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at test.rcp.Application.start(Application.java:34)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Caused by: java.lang.IllegalArgumentException: URI is not absolute
	at java.base/java.net.URL.fromURI(Unknown Source)
	at java.base/java.net.URI.toURL(Unknown Source)
	at org.eclipse.ui.internal.WorkbenchPage.fixOrphanPerspective(WorkbenchPage.java:4027)
	at org.eclipse.ui.internal.WorkbenchPage.getPerspective(WorkbenchPage.java:3991)
	at org.eclipse.ui.internal.WorkbenchPage.getActivePerspective(WorkbenchPage.java:4510)
	at org.eclipse.ui.internal.WorkbenchPage.updatePerspectiveActionSets(WorkbenchPage.java:4934)
	at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:750)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	... 129 more
The error is located on this line : int returnCode = PlatformUI.createAndRunWorkbench(display, workbenchAdvisor);
I can't find where does it come from. Does anyone have ever encoutered this problem or have any clue of what's going on ?
Many thanks in advance.
Valentin.
Re: Error with PlatformUI.createAndRunWorkbench method [message #1802413 is a reply to message #1786943] Fri, 08 February 2019 08:43 Go to previous message
I have the same problem Valentin.
Did you found a solution?
Jean-Marc
Previous Topic:Why the recent Eclipse "Language servers" features slow down so much the IDE
Next Topic:After upgrade to 4.10, can't find any eclipse plugins in build path etc
Current Time: Sun Jul 20 11:41:47 EDT 2025
Powered by FUDForum. Page generated in 0.02883 seconds
