Error opening workspace after installing e(fx) [message #1802085] |
Thu, 31 January 2019 17:57  |
!SESSION 2019-01-31 16:49:35.285 -----------------------------------------------
eclipse.buildId=4.10.0.I20181206-0815
java.version=11.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2019-01-31 16:49:36.811
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start() of bundle org.eclipse.equinox.p2.reconciler.dropins.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:803)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:732)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1005)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:357)
at org.eclipse.osgi.container.Module.doStart(Module.java:588)
at org.eclipse.osgi.container.Module.start(Module.java:456)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1763)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1725)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1656)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:343)
Caused by: java.lang.NoClassDefFoundError: javax/xml/parsers/DocumentBuilderFactory
at org.eclipse.equinox.internal.p2.core.helpers.SecureXMLUtil.newSecureDocumentBuilderFactory(SecureXMLUtil.java:33)
at org.eclipse.equinox.internal.p2.update.ConfigurationParser.load(ConfigurationParser.java:184)
at org.eclipse.equinox.internal.p2.update.ConfigurationParser.internalParse(ConfigurationParser.java:215)
at org.eclipse.equinox.internal.p2.update.ConfigurationParser.parse(ConfigurationParser.java:42)
at org.eclipse.equinox.internal.p2.update.ConfigurationIO.read(ConfigurationIO.java:46)
at org.eclipse.equinox.internal.p2.update.Configuration.load(Configuration.java:41)
at org.eclipse.equinox.internal.p2.reconciler.dropins.PlatformXmlListener.stopPoll(PlatformXmlListener.java:120)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.DirectoryWatcher.stopPoll(DirectoryWatcher.java:175)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.DirectoryWatcher.poll(DirectoryWatcher.java:113)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchConfiguration(Activator.java:498)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:177)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:782)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:775)
... 12 more
Caused by: java.lang.ClassNotFoundException: Could not find class 'javax.xml.parsers.DocumentBuilderFactory'
at org.eclipse.fx.osgi.fxloader.FXClassLoader.postFindClass(FXClassLoader.java:117)
at org.eclipse.osgi.internal.loader.BundleLoader.searchHooks(BundleLoader.java:527)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:490)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:153)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
... 27 more
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.createModuleLoader(FXClassLoader.java:177)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.findClassJavaFX11(FXClassLoader.java:160)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.postFindClass(FXClassLoader.java:115)
... 33 more
Caused by: java.lang.IllegalArgumentException: Module javafx.base not known to this layer
at java.base/java.lang.ModuleLayer.findLoader(ModuleLayer.java:885)
... 40 more
Root exception:
... 27 more
... 33 more
... 40 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-01-31 16:49:37.213
!MESSAGE Unable to create class 'org.eclipse.e4.ui.internal.workbench.ResourceHandler' from bundle '107'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: jdk/internal/reflect/ConstructorAccessorImpl
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:422)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:333)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:193)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:77)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:382)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:260)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:586)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
Caused by: java.lang.NoClassDefFoundError: jdk/internal/reflect/ConstructorAccessorImpl
at java.base/jdk.internal.misc.Unsafe.defineClass0(Native Method)
at java.base/jdk.internal.misc.Unsafe.defineClass(Unsafe.java:1192)
at java.base/jdk.internal.reflect.ClassDefiner.defineClass(ClassDefiner.java:63)
at java.base/jdk.internal.reflect.MethodAccessorGenerator$1.run(MethodAccessorGenerator.java:400)
at java.base/jdk.internal.reflect.MethodAccessorGenerator$1.run(MethodAccessorGenerator.java:394)
at java.base/jdk.internal.reflect.MethodAccessorGenerator.generate(MethodAccessorGenerator.java:393)
at java.base/jdk.internal.reflect.MethodAccessorGenerator.generateConstructor(MethodAccessorGenerator.java:92)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:55)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at java.base/java.lang.reflect.Proxy.newProxyInstance(Proxy.java:1022)
at java.base/java.lang.reflect.Proxy.newProxyInstance(Proxy.java:1008)
at java.base/sun.reflect.annotation.AnnotationParser$1.run(AnnotationParser.java:306)
at java.base/sun.reflect.annotation.AnnotationParser$1.run(AnnotationParser.java:304)
at java.base/sun.reflect.annotation.AnnotationParser.annotationForMap(AnnotationParser.java:304)
at java.base/sun.reflect.annotation.AnnotationParser.parseAnnotation2(AnnotationParser.java:294)
at java.base/sun.reflect.annotation.AnnotationParser.parseAnnotations2(AnnotationParser.java:121)
at java.base/sun.reflect.annotation.AnnotationParser.parseAnnotations(AnnotationParser.java:73)
at java.base/java.lang.reflect.Field.declaredAnnotations(Field.java:1175)
at java.base/java.lang.reflect.Field.declaredAnnotations(Field.java:1173)
at java.base/java.lang.reflect.Field.getAnnotation(Field.java:1142)
at java.base/java.lang.reflect.AnnotatedElement.isAnnotationPresent(AnnotatedElement.java:274)
at java.base/java.lang.reflect.AccessibleObject.isAnnotationPresent(AccessibleObject.java:517)
at org.eclipse.e4.core.internal.di.InjectorImpl.isAnnotationPresent(InjectorImpl.java:1039)
at org.eclipse.e4.core.internal.di.InjectorImpl.processFields(InjectorImpl.java:718)
at org.eclipse.e4.core.internal.di.InjectorImpl.processClass(InjectorImpl.java:677)
at org.eclipse.e4.core.internal.di.InjectorImpl.processClassHierarchy(InjectorImpl.java:658)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:115)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:411)
... 24 more
Caused by: java.lang.ClassNotFoundException: Could not find class 'jdk.internal.reflect.ConstructorAccessorImpl'
... 55 more
at java.base/jdk.internal.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
... 61 more
... 67 more
!ENTRY org.eclipse.epp.logging.aeri.ide 2 0 2019-01-31 16:49:37.240
!MESSAGE Could not resolve module: org.eclipse.epp.logging.aeri.ide [138]
Unresolved requirement: Import-Package: org.apache.lucene.document; version="[7.1.0,8.0.0)"
!ENTRY org.eclipse.osgi 4 0 2019-01-31 16:49:37.242
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:385)
FUDForum. Page generated in 0.05724 seconds
