Home » Modeling » Papyrus » Unable to Create Activity Diagram(Unable to Create Activity Diagram)
Unable to Create Activity Diagram [message #1801583] Tue, 22 January 2019 17:52 Go to next message
I am using Eclipse Papyrus 2018-09. I created a new model from File>New>Papyrus Model>SysML 1.4. I then added a new activity diagram to the model.
In the Palette, I only see Activity node. There is no Action node. So I dragged initial node and then two activity activity nodes. Now I tried the following:\
Connect initial node with First Activity node using a control flow. It doesn't allow me do it
Similarly, I tried to connect Activity node 1 and 2 using both control flow and object flow. In both cases it doesn't work.
I also tried to add input and output pins to activity nodes and then connect. I am facing the same problem.
Am I missing something ? Can someone point me in the right direction ?
Hussain
Re: Unable to Create Activity Diagram [message #1801851 is a reply to message #1801583] Mon, 28 January 2019 07:59 Go to previous messageGo to next message
Hi Hussain,
I just test it and it works for me, I get a correct palette with some actions (like CallBehaviorAction or AcceptEventAction see picture) and I can create nodes and links.
Are you sure you did not install an other plugin whose create a conflict ?
Pauline
Re: Unable to Create Activity Diagram [message #1801960 is a reply to message #1801851] Tue, 29 January 2019 18:33 Go to previous messageGo to next message
Hi Pauline,
I get the same palette as the one in your attachment, which also does not have an action node. Per my limited understanding of SysML, An Activity node is composed of multiple action nodes and Call Behaviour, Accept Event and Send Signal Action are specialised form of Action node. They are themselves not action node.
My goal was create simulation as shown in this link using sysml activity diagram: https://www.youtube.com/watch?v=ddogjaCtEbE
Am i doing something wrong ?
Re: Unable to Create Activity Diagram [message #1801981 is a reply to message #1801960] Wed, 30 January 2019 04:24 Go to previous messageGo to next message
Hi Hussain,
Sorry I did not understand you question well. In my opinion you cannot instantiate an Action since Action is Abstract that means that you can only instantiate specialisation of Action like CallBehaviorAction, AcceptEventAction, ... which are actually Actions since there extends Actions.
Pauline
Re: Unable to Create Activity Diagram [message #1802017 is a reply to message #1801981] Wed, 30 January 2019 16:44 Go to previous message
Hi, Thanks for the response.
I figured that in SysML Palette If I want to see Opaque Action, I need use customise palette option and from choose required nodes/edges from UML Palette.
Hussain
Previous Topic:New Papyrus Model Wizard Won't Close On Finish
Next Topic:Defining attribute text constants on class diagram
Current Time: Sat Jul 19 18:24:22 EDT 2025
Powered by FUDForum. Page generated in 0.04493 seconds
