Home » Eclipse Projects » Eclipse USS SDK » USS usability(USS usability)
USS usability [message #1801863] Mon, 28 January 2019 10:24 Go to next message
Please explain a few questions
1. Why USS does not synchronize settings when starting IDE?
2. Why does USS synchronize settings only after clicking Window -> Preferences -> Oomph -> Setup Tasks -> Preference Synchronizer -> Synchronize Now ... ?
3. Please describe how you see the working scenario of using USS by Eclipse user. Because we are testing USS client usage and dont understand how to use it correctly. We expect that user settings will be synchronized when you start the Eclipse IDE, when you press the Help -> Perform Setup Tasks key. But synchronization does not occur during the above described actions.
4. Why USS does not synchronize settings if there is an active Oomph task in the lower right corner of the screen?
Re: USS usability [message #1801927 is a reply to message #1801863] Tue, 29 January 2019 10:00 Go to previous messageGo to next message
Hi Dmitry,
I will do my best to answer some of your questions. I am responsible for the API server which is used by USS SDK but I did not write any code for the Oomph/USS SDK in the ECLIPSE IDE.
Preference synchronizing must be allowed by the user and they must opt-in. We don't store preference without authorization by the user.
At the very least, our API will not accept any preferences without an access token with the required scope which is only given if the user granted access to Oomph to do so.
Oomph must be enabled first to synchronize preferences. I would recommend asking this questions in the Oomph forum to additional information: https://www.eclipse.org/forums/index.php/f/287/
Re: USS usability [message #1801929 is a reply to message #1801927] Tue, 29 January 2019 10:12 Go to previous message
Thank you very much!
Why USS server code is not open source?
Current Time: Sat Jul 19 09:50:45 EDT 2025
Powered by FUDForum. Page generated in 0.04582 seconds
