Home » Eclipse Projects » Kura » Using Kura (v4) in container
Using Kura (v4) in container [message #1801831] Mon, 28 January 2019 03:07 Go to next message
Does the containerized provide the same functionality as those for physical platforms (like the one for raspberry)?
What I am trying to do is running a Kura instance in Docker and connecting a device by Modbus over Ethernet to it.
Kura runs successfully, and I was able to install the Modbus add-on (https://marketplace.eclipse.org/content/modbus-protocol-implementation-eclipse-kura-4xy) but in the section Drivers it says that no drivers are available, also the instance seems to be missing some menu sections like Network or Firewall.
Could it be that I am missing something or is the containerized form not intended to provide this ability?
Re: Using Kura (v4) in container [message #1802031 is a reply to message #1801831] Thu, 31 January 2019 02:30 Go to previous message
The containerised version of Kura is a NN (no network) version of the framework. This means that it will not be able to change the network and firewall configuration of your host system. That is why you don't see the Network and Firewall tabs.
With that said, the applications on top can operate independently of this. So, you should be able to communicate with Modbus TCP devices.
Did you try to have a look at the log to understand what is going on?
Matteo
Previous Topic:Create new database connection type
Next Topic:PTC Thingworx
Current Time: Sun Jul 20 05:45:04 EDT 2025
Powered by FUDForum. Page generated in 0.56832 seconds
