Home » Newcomers » Newcomers » Eclipse Titan(No Titan is found on the titan preference)
Eclipse Titan [message #1801625] Wed, 23 January 2019 14:07 Go to next message
Hii I am installing the Eclipse titan using the cygwin
I am able to run the make -j command and make install command .Not able to fetch the packages in make install directory. Also I m not able to find the compiler on the path C:/cygwin/home/userid/install
Requesting you to guide and giveme the Quick solution on this query
Re: Eclipse Titan [message #1801640 is a reply to message #1801625] Thu, 24 January 2019 00:24 Go to previous message
I believe this the the Titan forum:
https://www.eclipse.org/forums/index.php/f/297/
Previous Topic:Cant Install
Next Topic:Set locale based on data
Current Time: Sun Jul 20 14:56:28 EDT 2025
Powered by FUDForum. Page generated in 0.79446 seconds
