Unable to Create Activity Diagram [message #1801583] |
Tue, 22 January 2019 17:52  |
I am using Eclipse Papyrus 2018-09. I created a new model from File>New>Papyrus Model>SysML 1.4. I then added a new activity diagram to the model.
In the Palette, I only see Activity node. There is no Action node. So I dragged initial node and then two activity activity nodes. Now I tried the following:\
Connect initial node with First Activity node using a control flow. It doesn't allow me do it
Similarly, I tried to connect Activity node 1 and 2 using both control flow and object flow. In both cases it doesn't work.
I also tried to add input and output pins to activity nodes and then connect. I am facing the same problem.
Am I missing something ? Can someone point me in the right direction ?
Hussain
FUDForum. Page generated in 0.05819 seconds
