Home » Newcomers » Newcomers » ViewPart moved after installation
ViewPart moved after installation [message #1801445] Sat, 19 January 2019 06:22 Go to next message
https://raw.githubusercontent.com/angel539/extremo/gh-pages/images/VirtualBox_ExtremoE_19_01_2019_12_14_59.png
Hi all,
after having installed my own plugin with an Update Site I have created the views (all of them) seems to be displaced (or moved) but in the internal canvas, not with respect the possition I indicated for them in the perspective.
Do you have any clue of what is happening? Can be due some information I have missed in the MANIFEST.MF of the original projects?
All the best,
Ángel
[Updated on: Sat, 19 January 2019 06:23] by Moderator
Re: ViewPart moved after installation [message #1801446 is a reply to message #1801445] Sat, 19 January 2019 07:34 Go to previous messageGo to next message
When you resize the window or the elements in the window, this strange effect persists? If you move/rearrange the views, the strange effect persists? If you reset the perspective it, that doesn't fix it either?
Re: ViewPart moved after installation [message #1801462 is a reply to message #1801446] Sun, 20 January 2019 07:21 Go to previous messageGo to next message
Hi!,
Thanks for your answer!
Yes, it persists.
Yes, it persists.
Yes, if I reset the perspective, it doesn't fix.
Angel
Re: ViewPart moved after installation [message #1801492 is a reply to message #1801462] Mon, 21 January 2019 03:31 Go to previous message
Hmmm, it's hard to say without knowing what you did to create/define/initialize this perspective but you will probably want to compare how you do that with how other perspectives are implemented without this problem/effect.
Previous Topic:Debugging an Eclipse + Kotlin + Gradle project?
Next Topic:Papyrus
Current Time: Sun Jul 20 09:52:30 EDT 2025
Powered by FUDForum. Page generated in 0.12979 seconds
