Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Does forte support snapshot of forte runtime?(Does forte support snapshot of forte runtime?)
Does forte support snapshot of forte runtime? [message #1801283] Wed, 16 January 2019 02:10 Go to next message
Does forte support snapshot of forte runtime? If forte has, any interfaces to get the snapshot history data?
Re: Does forte support snapshot of forte runtime? [message #1801295 is a reply to message #1801283] Wed, 16 January 2019 04:25 Go to previous messageGo to next message
No currently not. What would be your use case? Maybe other means are available for you.
Re: Does forte support snapshot of forte runtime? [message #1801383 is a reply to message #1801295] Thu, 17 January 2019 21:33 Go to previous messageGo to next message
Use case:
Pause the application running on FORTE. After some operations, User can resume the application
[Updated on: Thu, 17 January 2019 21:34] by Moderator
Re: Does forte support snapshot of forte runtime? [message #1801392 is a reply to message #1801383] Fri, 18 January 2019 03:30 Go to previous message
Thanks for the clarification. I would use this use case on application level. The event mechanism of IEC 61499 is very well suited for that. So you can determine when your application should run and when not and based on start, stop events coming maybe from an HMI or some other application.
Previous Topic:Eclipse and long pathnames
Next Topic:Connection closed by peer
Current Time: Sun Jul 20 06:09:28 EDT 2025
Powered by FUDForum. Page generated in 0.24641 seconds
