Home » Archived » Eclipse SmartHome » Swipe functionality for Dimmer/volume controls(Swipe functionality for Dimmer/volume controls)
Swipe functionality for Dimmer/volume controls [message #1801099] Sun, 13 January 2019 17:20 Go to next message
Hi All,
Can anyone indicate when this will be available or if anyone is working on adding Swipe control to the ESH framework ? Specifically for OpenHab to allow zwave devices such as WallMotes to control Dimming and or Volume?
To increase the ease of use for non tech users of home automation systems this would be a huge value add I think (especially for the wives!)
Thank you!
Re: Swipe functionality for Dimmer/volume controls [message #1801368 is a reply to message #1801099] Thu, 17 January 2019 10:57 Go to previous messageGo to next message
Hi Kris,
this is a very UI specific feature request. You may enter an issue with more details on which UI you want to be improved at the ESH issue tracker at https://github.com/eclipse/smarthome.
Thanks.
Re: Swipe functionality for Dimmer/volume controls [message #1801374 is a reply to message #1801368] Thu, 17 January 2019 14:53 Go to previous messageGo to next message
Hi, the link does not work
This is for openhab2
Thanks!
Re: Swipe functionality for Dimmer/volume controls [message #1801400 is a reply to message #1801374] Fri, 18 January 2019 04:58 Go to previous message
Then I suggest you head over to the openHAB forums at https://community.openhab.org . This forum is used for the underlying framework Eclipse SmartHome.
Previous Topic:Flexibility of framework and supplied types
Next Topic:Project currently stalled - do not expect answers here!
Current Time: Sun Jul 20 18:03:59 EDT 2025
Powered by FUDForum. Page generated in 0.03787 seconds
